SSD issue
- Timeline
SSD issue
I bought a new 2GB SSD supposedly comparable with the latest OS X but it will not upgrade to latest version os x. Window comes up and says drive the issue yet it runs fine, just not in Serra. Would a reformat work?
Re: SSD issue
2GB? You meant 2 TB, I assume.
Re: SSD issue
You need to do that if you intend to boot a Mac from it. If planning to use as an external drive, it's a very good idea and may cause problems if you don't.Would a reformat work?
If you are running Sierra, boot into the Repair Partition and run Disk Utility from there.
There are many threads on this issue. If you tell us exactly what you want to do, one of us can probably link to the right one.
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.4, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3 6/10/12; 2012 MBPs Catalina, Mojave
- Timeline
Re: SSD issue
YesMIDI Life Crisis wrote:2GB? You meant 2 TB, I assume.
Hi Mike yes, I am running latest versionOS X pre sierra. Just want to try Sierra going.
