Sustain works properly with VIs until one tries to record over pre-existing MIDI data at which time the sustain pedal ceases to function while recording until all pre-recorded MIDI data has been overwritten
- Set up MIDI track routed to any VI (tested with Ivory, Contact and Omnisphere).
Record VI such as piano or electric piano using MIDI Controller and sustain pedal.
While recording, note sustain pedal functions properly; the VI will respond as it should.
Roll to beginning
Record again on same track. Note that while recording, until the end of previously recorded data is reached, sustain pedal does not effect the VI while recording.
On playback, all pedaling is heard properly, despite the fact it could not be heard while recording.
Submitted Tech Note to MOTU. Anybody else encounter this or found a fix? Thanks!
