Live Room B Missing
Live Room B Missing
I have DP7.24 installed on my 2010 27" iMac (El Capitan) and 2011 Macbook Pro (Sierra). The MacBook Pro has Live Room B but the iMac doesn't. The MBP is new to me an upgrade from my 2006 Macbook (Lion) which also had Live room B on it. Does anyone have any ideas why or how I can fix this?
27" iMac 2.8GHz Quad Core i5• 32 GB RAM • 1 TB SSD • OS 10.13.6
MacBook Pro 2.9GHz i5 • 8GB RAM • 500GB SSD • OS 12.7.2
MOTU 896mk3h
DP 9.52
MOTU 896mk3h
DP 9.52
Re: Live Room B Missing
A reinstall should fix it, and shouldn't take too long.
828x MacOS 13.6.5 M1 Studio Max 1TB 64G DP11.31
Thanks. Was hoping to avoid that. I'm in the middle of a project so I guess I'll wait till I finish that first.
MOTU 896mk3h
DP 9.52
MOTU 896mk3h
DP 9.52
Reinstalling does not mess with your project. It does not touch your settings, preferences or files.Graywolf wrote:Thanks. Was hoping to avoid that. I'm in the middle of a project so I guess I'll wait till I finish that first.
Ideally, it should be done from your 7.24 CD. Run the installer, select Uninstall from the drop down menu and run it. Next, run the installer. Authorize from the CD if necessary.Run permissions repair.
If you do not have the 7.24 CD installer file, do the above from the 7.24 Updater download, then from your original CD. Reverse to install.
Do not do this in Sierra. DP will no longer correctly install in OS 10.12.x. It can be installed in El Cap or earlier or be migrated from a correct install.
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.4, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3 6/10/12; 2012 MBPs Catalina, Mojave
