Never seen this before... [RESOLVED]
I enter a MIDI drum pattern using Superior Drummer like I have done for years years and now when I try to change the velocity of a single note in the info bar, it defaults to 127. Can not change it. Tried a new file and restarted computer and rig. Kinda baffled.
Any one know what is causing this?
Thanks,
Mike
Thanks,
Mike
Re: Never seen this before...
Well, time to cancel session and start figuring out why this is happening. I've re-plugged in my usb devices (computer keyboard, trackball, etc.)
Restarted all gear and computer. When I enter MIDI data on my piano keyboard within DP, the velocities are what ever I put in. Only when I click on the velocity information window and I try to change it, the velocity changes to 127. I change it again and it instantly changes back to 127. Would something be set to default to 127 if tried to change it?
Any help would be appreciated...
Thanks, Mike
DP 9.0.2
OS 10.10.5
Thanks, Mike
DP 9.0.2
OS 10.10.5
That's a weird one, for sure!! I haven't ever seen that in DP, and I'm racking (wracking?) my brain trying to think of something that would cause that.
The only little troubleshooting thing I can think of would be to create a new OS user (just for testing, you can trash it afterwards)-- and just see if the behavior happens if you are logged in as different user. A corrupt preference?
MH often suggests reinstalling DP9 then repairing permissions. Which sounds like it might be a reasonably safe step to take.
If you haven't started a support ticket with MOTU, that would be a good next step. They can walk you through some other things to try-- like launching DP in different modes.
GOOD LUCK!!!
GOOD LUCK!!!
Call MOTU?
- buzzsmith
Is the track armed to record?
Does the velocity field kinda flicker when it jumps back to 127?
Could be that (for some reason) your controller keyboard is generating these MIDI events.
Try disarming record and maybe even input and see if you can change those velocities.
Just a thought!
Buzzy
Just a thought!
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Thanks guys...I found out it was a MIDI pulse coming from my Ramsa mixer. I disconnected the MIDI cables from it and everything is back to normal. Not sure why the mixer started doing this. I don't use the it for anything except monitoring anyhow so it works fine without MIDI connections.
Thanks again for your suggestions...
Mike
Mike
Re: Never seen this before... [RESOLVED]
Buzzy called it!!
Sometimes if a fader is kind of between values (?) or perhaps dirty (?), even little vibrations can cause it to send out values-- even when they aren't being deliberately changed. I had this with a controller (though it was doing something quite different than your case). I worked the right fader up & down a few times and it never happened again.
I'm really glad you started this thread, because this is just the kind of thing we'd forget about-- i.e., that some random MIDI CC could be changing values in a random field like that.
I'm so glad you figured it out so quickly! (Thanks to Buzzy-- or maybe you figured it out before he did?)
Hello,
My Ramsa Da7 started having a related error 3 years ago.
When I drive the faders in DP with the Da7 MIDI Fader Layer they work for a while then suddenly stop. I can then re-attach the MIDI controllers and it starts working again. I used a long ago required trouble shooting tool that looks at the MIDI data and saves the stream to a file so I can look it over. Turns out the MIDI note associated with each fader changed. Sometimes all the faders have the same note. I have yet to tear into it to see if I can diagnose the problem. It has to be the MIDI "IC" on the main board going wonky when it's been on a while. I still love the A/D on the Ramsa, nice little board.
It's the ear, not the gear!
