I've just posted, and then Updated, my recent post of 'From DP 9.12 back to 9.02'
Things were working great, until I quit DP and then came back to it and opened up the same project.
Upon re-opening, I had audio artifacts problems. The plugins were in 'PreGen' mode.
If I get them to run in 'RealTime' mode, then all is well again.
Maybe when I first opened up my new 9.02 and imported my project, they initially loaded in 'RealTime' mode?....because all was beautiful.
Anyways, now all is fine when I run the plugins in 'RealTime' mode on my system and 9.02. (...or in DP 8.07 too!)
And, with 9.12, the audio artifacts are still happening whether I use 'PreGen' or 'RealTime' mode. Makes no difference. Have to go and use 9.02 on my system.
Update over for now....
Definitely a 'PreGen' mode problem
DP 11, OS Ventura
http://www.cammillarmusic.com
Re: Definitely a 'PreGen' mode problem
This belongs in the Troubleshooting / Criticism forum.
Mac Studio M1 Max, 64GB/2TB, MacOS 14.4.1 Sonoma, DP 11.31, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Console 1 Mk2, Avid S3, NI Komplete Kontrol S88 Mk2, Red Type B, Millennia HV-3C, Warm Audio WA-2A, AudioScape 76F, Dean guitars, Marshall amps, etc., etc.!
Yes, will repost any other tech things like this is the other forum.
DP 11, OS Ventura
Thanks. I moved it. I was away from my computer earlier and using Tapatalk, so I mostly replied so that I could find this topic later in order to move it the the appropriate forum.artfarm1 wrote:Yes, will repost any other tech things like this is the other forum.
