Hi all, It's been a really long time (since like, the '90's).
I'm running DP7 and am thinking of upgrading to DP9, but frankly, I can't take advantage of the 64-bit processing fully since I would have to spend possible thousands of dollars to upgrade Mach Five, East-West Symphony Orchestra and Play.
Therefore, since I have been told that there are advantages of running DP9 in 32-bit mode in spite of the drawbacks mentioned above, what is the consensus regarding issues like:
1. Will the new MAS Audio Engine significantly improve virtual instrument performance, viz., reducing processor overload and therefore hardware overheating;
2. Would my situation be better served by my installing an SSD instead of upgrading DP?
Many Thanks and I would prefer a heads up off the list via my email, which is roger@rogerhuntmusic.com
Roger Hunt
MAS Audio Engine performance on DP9 in 32-Bit Mode
Re: MAS Audio Engine performance on DP9 in 32-Bit Mode
Absolutely switch to an SSD. The Samsung 850 EVO goes for $250 for a 1T and $600 for a 2T if you shop around. Everything including DP runs faster and your Mac will run cooler.
Mac Pro towers and iMacs require a $10 bracket. Late 2009 and later iMacs also require a $37 replacement heat sensor—there are two depending on the year, 2009–10 and 2011–on.
Enable TRIM. How depends on your OS.
Replace the NV RAM battery if five years old or older. CR2032 for MP towers and iMacs older than 2011. BR2032 for all other desktop Intel Macs due to higher heat tolerance.
I can't answer for the performance of MAS in 32bit as I still keep 7.24 installed for the rare occasion when I need to run old files with 32bit only plugs.
