Bars and Lines mode for Note Velocity?
Am I just dense, or silly for wondering this, but would it be useful in the MIDI Editor window to have Bars mode and Lines mode work for note on velocities as well as controllers? At least visually it would be a hell of a lot easier to see than Points mode.
Re: Bars and Lines mode for Note Velocity?
I thought it would be a good idea too, but I suppose the logic is that velocities are not independent events; they're one of the data points in a note event, while controller events are independent of any other event. Not to say it couldn't be done if MOTU programmers wanted to do it.
Right... just seems like it would be easier to see that way. A visual aid is all. Sometimes... well a lot of times, I want to ramp note velocities.bayswater wrote:I thought it would be a good idea too, but I suppose the logic is that velocities are not independent events; they're one of the data points in a note event, while controller events are independent of any other event. Not to say it couldn't be done if MOTU programmers wanted to do it.
I agree. For now you just have to use Smooth option in the Velocity command dialog, or the reshape tool which shows you the "line" as long as you're in the process of drawing the ramp.James Steele wrote:Right... just seems like it would be easier to see that way. A visual aid is all. Sometimes... well a lot of times, I want to ramp note velocities.
Yeah... I use that and it helps. I guess my main beef is those tiny little "Vs" the denote the note velocity are SO SMALL!!! Especially on my 30" monitor. I think amplidood had some themes with thicker velocity point icons. I sure hope he can update his themes some day for 9.1xbayswater wrote:...or the reshape tool which shows you the "line" as long as you're in the process of drawing the ramp.
Yes!!!James Steele wrote:...would it be useful in the MIDI Editor window to have Bars mode and Lines mode work for note on velocities as well as controllers?...
- Guitar Gaz
James - this has been posted a few times - it is not perfect but this png from the Resources folder of your favourite theme can be amended at least makes the V's into square blocks (any colour you like to make them) and so are easier to see :James Steele wrote:Yeah... I use that and it helps. I guess my main beef is those tiny little "Vs" the denote the note velocity are SO SMALL!!! Especially on my 30" monitor. I think amplidood had some themes with thicker velocity point icons. I sure hope he can update his themes some day for 9.1xbayswater wrote:...or the reshape tool which shows you the "line" as long as you're in the process of drawing the ramp.
and looks like this:
Called cdDataCicn.png if you can access it with a paint/graphics program you can manually alter the file. If you can't do this I would be happy to send you the file (any colour you like) so you can slip it in the Resources folder. You usually need both the normal and the 5k version depending on the Mac you are using.
Cheers,
Gary
Gary Shepherd
____________
iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Monterey 12.7.4, 64 bit, Digital Performer 11.3, Studio One 6.6 Professional, Reason 11, Melodyne 5 Editor, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 3.72, Bias FX 2 Elite, Superior Drummer 3, EZkeys, EZbass, Nektar Panorama T4, Motu M4, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear.
____________
The thing that makes it a little less-than-ideal, is that we are often dealing with polyphony and might not like to have all members of the chord be the same velocity-- especially if we are dealing with things like counterpoint, etc.
One option would be to display velocity in a 3D field where X/Y/Z are time/velocity/pitch respectively. Some kind of altered scroll could move through the available pitches at any given point in time in some controlled but organic way (?)
- Guitar Gaz
Will I have to wear those 3D glasses like at the movies?stubbsonic wrote: One option would be to display velocity in a 3D field where X/Y/Z are time/velocity/pitch respectively. Some kind of altered scroll could move through the available pitches at any given point in time in some controlled but organic way (?)
Gary Shepherd
____________
____________
Ahhh right. I was looking at a bass part when I thought of it. Wasn't thinking about chords. Doh!
Cheers,
Gary
Forgive my ignorance, but what is this 5K people keep referring to?
- Timeline
I would like that.James Steele wrote:Am I just dense, or silly for wondering this, but would it be useful in the MIDI Editor window to have Bars mode and Lines mode work for note on velocities as well as controllers? At least visually it would be a hell of a lot easier to see than Points mode.
Also to be able to switch any track to quick scribe without loosing the other tracks. It would just be more tactile to me.
The one feature I would love as well and have been asking for for 5 years is a lock the vertical window scroll button which would allow you to move down the sequence without loosing your place because of mouse accidental movements causing scrolling on a track to move up or down.
Pretty sure as in "5k Video Monitor", and the corresponding DP graphics files, the iMac standard.Phil O wrote:Forgive my ignorance, but what is this 5K people keep referring to?
- Guitar Gaz
The resolution on a 5K Retina Mac requires some DP png's to be @2 times the size - so the Themes resources have double the number of png's in some cases.Phil O wrote:Forgive my ignorance, but what is this 5K people keep referring to?
Gary Shepherd
____________
____________
