Memory cycle and recording MIDI behaviour
I have a problem when I record MIDI tracks with the memory cycle on. It records something that affect the length of my first beat to a short note and it only plays the short data at the first beat, the first time of the cycle. Anybody is having that problem? I don't see anything in the MIDI data.
I'm with El Capitan and the latest version of DP.
iMac 27" i7 4.0, 3Te.32 G of Ram, Apollo Silver with TB expansion (coming up).
Re: Memory cycle and recording MIDI behaviour
When you say you "don't see anything in the MIDI data", is the note value is incorrect in the data? i.e., you played a quarter note when you recorded, but the data says it's a 1/16th note? Or is the data saying it's a quarter note, but it only plays a 1/16th?
Is your Overdub button on? I've sometimes had issues when loop recording at the start.
Is Multi Record mode on (are you recording several different MIDI channels at once?)
MacBook Pro 9,1 (mid-2012 Core i7 2.3 GHz 4 GB RAM), OSX 10.11.3, Newertech Voyager SATA drive dock
MOTU: DP 9.02, Traveler Mk 1, 896 MkIII Hybrid, MIDI Express XT
Alesis AI3 optical interface, QS8, QS7, DM Pro, DM5, QSR
Mackie Controller and Extender (original MIDI)
Pro Tools 12
Pro Tools 12
Thanks for the reply.
The value of the MIDI note is correct meaning it could be a long value but I get a very short note instead when I play back, on the cycle repeat it seems ok. Overdub is On sometimes and multi-record also but not using it. I'll check. Even this morning trying to freeze a Kontakt pad, it did the same thing. I'm going crazy over this
Are you quantizing?
If not, maybe the first note, instead of starting at (for example) 4|1|000, is at 3|4|470, and when the loop restarts the first time it cuts it off?
What happens if you nudge your loop start point earlier by 5 or 10 ticks?
Pro Tools 12
Pro Tools 12
I did that too. Nothing helps.
Anyway, I throw the towel, I just loaded Logic. I think I'm done with DP after all those years.
BTW, which OS X are you using now?
It is at least possible in my mind that some of the MIDI problems reported have something to do with OS X updates affecting the Audio MIDI Setup utility. My evidence for this is that Pro Tools users are reporting MIDI timing errors they didn't used to have.
Logic, being under Apple's umbrella, might be more aware of what's going on "under the hood" than external developers . I'm not sure that Apple is spending as much time and money on OS development, as it's a declining market in their eyes.
Or, perhaps the heavy hitters there are all working in secret on a bulletproof, mission-critical OS11 operating system that will be immune to all hackers and never crash. Perhaps Steve Jobs faked his death and has been hiding in a mountaintop retreat browbeating a group of engineers until they get it up to his standards.
Pro Tools 12
Pro Tools 12
Thanks for your reply. I didn't update my profil in a while indeed ElCapitan on a imac 2009.TinenTech wrote:
I will give DP a last chance. I just order a brand new iMac with 32 G of Ram, i7 processor and a 3To Fusion drive. It better rock.... .
Sly
