Hi all. I've just spent 2 days setting up a template to work with VEP6 and have hit two stumbling blocks I hope you can help with.
I'm routing out of Vep6 back into DP via bundles. I then put the blue speaker light on each of the corresponding audio tracks so I can hear the returns from vep6 . When I want to record the audio in I mute my reverbs so that I record dry tracks. However if I press solo and go into piano roll I vent hear anything. Does any one know why or have a better way of bringing the audio back into DP. All my MIDI is recorded as audio before it's sent online to my mix engineer.
The second problem is latency anyone know what to do to improve this?
Thanks brolly
DP/VEP6 no solo.
Re: DP/VEP6 no solo.
If you want to solo a VI track, you have to make sure the MIDI tracks are solo exempt. In the tracks overview, one of the columns is "XMPT". Select that for the MIDI track so that when you solo the VI, the MIDI will be there to play it.
Thanks Killahurts i'll look at that tomorrow.
I'm also now using auxiliaries to return from VEP6 and sending feeds to audio tracks, works like a dream.
brolly xx
brolly xx
I do that too, and I have a lot of tracks.. DP handles it easily!brolly wrote:I'm also now using auxiliaries to return from VEP6 and sending feeds to audio tracks, works like a dream.
brolly xx
