DP9.1 BFD2-3 incompatible with older projects sparaticlly
- Timeline
I tried to open an 8 mix in 9 and the MIDI is there where its supposed to be but the drums are a quarter note behind. Re-opened in 8 and its fine?
ROLLED BACK TO 9.02 to solve as workaround.
Loved the sound of 9.1 though.
Re: DP9 and BFD appears incompatible
I'm using BFD3 everyday recording in realtime using roland edrums to trigger at 128 buffer. It works great. I have it set to highest velocity and I am using a big set with lots of cymbals.
Magic Dave said the lower the buffer the better but it chokes at 64. So I am mixing now at 562 and cutting at 128.
waxman
- Robert Randolph
BFD 3 is working great here in DP 9.02 for me. Not so well in 9.1Timeline wrote:I tried to open an 8 mix in 9 and the MIDI is there where its supposed to be but the drums are a quarter note behind. Re-opened in 8 and its fine. What the heck?
Could you give us more information about your setup? Considering that there's a few folks using BFD without issue in DP 9, it would seem that there's something we need to track down on your system.
- Timeline
Have either of you tried to recall an 8 mix from DP8? Could be the BFD version I had on the old mixes was from BFD 2. Possibly I need to replace that into BFD3waxman wrote:I'm using BFD3 everyday recording in realtime using roland edrums to trigger at 128 buffer. It works great. I have it set to highest velocity and I am using a big set with lots of cymbals.
- Robert Randolph
I only have BFD 3, so I can't really check recall with BFD 2. Sorry.
- Timeline
I'm sure it works fine on new projects. I think this is likely a bad chunk issue. I'll try moving the old project into a new 9.1 project ...
