This definitely needs to be fixed. Major DP shortcoming...
Re: This definitely needs to be fixed. Major DP shortcoming.
Post by Shooshie »
A few days ago, I sent this in to MOTU as a tech link. It may be a while, but there's a very good chance we'll see this in an update one of these days. I thought you all might like to see the response:
MTL 104576 — Optional "Keep Takes Together When Editing"
  • Since take comping has dramatically increased the utility of takes, many of us believe there should be a preference default option AND a temporary setting in edit window headers to keep takes together. When we have 20 takes, and we want to cut a section out of the song, or move a section elsewhere, it is impractical to edit all the takes the same way. Consequently, it's necessary to do all take comping FIRST, and never to come back to it again. A simple radio button or check box beside the words "keep takes together," first as a default behavior in Preferences, and 2nd as temporary setting in the edit windows, would suit just about everyone.
Responses
Added by Brian_M on 2016/07/08 21:10:39 Universal
State change from 'Unread' to 'In progress'
  • Hi Shooshie,
    Thanks for writing. I agree that this would be a great feature, and I see how it would greatly improve productivity. I've forwarded this case to the DP Development Team for consideration in future DP updates.
FMiguelez
Post by FMiguelez »
Nice!
Thank you, Shoosh :)
I can´t wait to see this implemented.
Post by Shooshie »
FMiguelez wrote:Nice!
Don't get your hopes up. You know they're probably near the end of their 9.1 testing. I doubt they'll go back in and add something that big at this stage of development. We probably won't see this until 10.0, or at best 9.5. MOTU, make a liar out of me and get it out with the next release! But I won't hold my breath. It will be great to see it when it does get here.
toodamnhip
Post by toodamnhip »
Is there still no way to include sub takes in edits? The way it stands now, I have to expand out all takes before and edit if I want sub takes to move along with the edits. This cause various problems. I seem to recall a past version of DP having the option to include sub takes in region and other edits? Did they get rid of this feature? Why?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
FMiguelez
Post by FMiguelez »
No. You still have to explode/implode takes for that.
Same issue with folders. They must be opened first.
And yes. I do remember, at least with folders, we used to have an option to include/exclude their contents, around DP7, I think.
Maybe they'll give us better tools to handle this in DP10?
Timeline
Post by Timeline »
DP 10?????
Great they charge us 200 bucks for •••• they have broken. Doesn't sound fair to me. Maybe its time to look at ProTools virtual.
Mind the door on you're way out. :rofl:
2013 Mac Pro 32GB RAM
Timeline
Post by Timeline »
MIDI Life Crisis wrote:Mind the door on you're way out. :rofl:
What an ****
I have been a DP user before it dealt with audio MLC.
I have paid for every update including 6 that I never used for issue reasons.
The best versions were 3-5. 7, 8 and I happen to like 9.12 but it crashes on me with large projects
Your comment and attitude promotes this veterans reason to consider such a move.
I know Larry Hinds, a great musician who is also a DP veteran, HAS moved and tells me its much better these days than it used to be.
Maybe I'll give it a try as its cheap enough now.
LATER
Lighten up, man. You need to get a sense of humor. Not all comments are as ad hominem as your "what an ..." comment was. It's called humor. :roll:
Timeline
Post by Timeline »
Sounded like a typical fanboy expulsion to me.
Maybe you should think twice on how your comments might be interpreted.
I'm not here for the humor or deconstructing satyric comments, I'm here to solve issues that might help me with my ongoing production concerning DP9.
Fine. Block me. I'm doing that for you now, so your further comments will not be responded to.
Have at it. :dance:
Timeline
Post by Timeline »
Thanks, I appreciate. I don't block anyone.
Gravity Jim
Post by Gravity Jim »
Timeline wrote:DP 10?????
I think the response you got was because this isn't °°°° Motu has "broken:" once again, I feel the need to point out that this ISN'T a bug or an existing feature broken, it's simple an unincorporated feature.
After 5 pages of discussion in support of a simple suggestion, spitting nails at MOTU and threatening go check out another DAW doesn't make sense. Also, as you learned from MLC, nobody cares.
Now, if you want ProTools, knock yourself out. I have two DAWs, too, but you can bet one of them won't ever be that heavy-laden kludge from Avid.
Jim Bordner
