New Pitch Automation Not Loading in DP file
After editing pitch automation in numerous sound files, I successfully loaded the chunks into a new DP9 file.
But the new pitch automation did not follow. DP reverts back to the original pitch reading when the files were recorded.
I tried the clipping window to load these files and the same problem occurs.
I tried merging the soundbites before exporting and it still reverts back to the original pitch reading after the merge. Weird...
This happens in DP8 as well.
The only thing that works is when I bounce or record the sound file with the new pitch automation. Then it reads the new pitch automation accurately.
This process is time consuming. If someone has a better way or if I'm doing something wrong, please help.
Thanks in advance!
Gallospole posting.php?mode=post&f=1#
Thanks in advance!
MacBook Pro 2.3 GHz Intel Core i7 (2), 16 GB RAM, 512 SSD, OS 10.9.5 & OS 10.11.6/ MOTU DP 8.07 & 9.12 / Avid Artist Mix / Novation ReMOTE 25 / MOTU 828 mk3 Hybrid / MOTU MX4 / M Tron Pro / impOSCar 2 / Eventide Plugins, SSL 4000 E & G Plugins, Puigtec & Puigchild Plugins / Eventide H3000 SE Ultra Harmonizer / Rupert Neve Designs 551s / Heritage '73EQ Jr / Klark Teknik DN500 / UA 2-610 / Focusrite ISA 828 / Beyer M201 TG / AKG 414 B-ULS / Shure SM57 & Beta 87A / EV RE20
Re: New Pitch Automation Not Loading in DP file
I think that's one for Magic Dave. If there's a way, he probably knows. If not, he probably knows why.
Magic Dave as in Dave Roberts?
Thanks for your reply!
If you haven't posted a Tech Link with support, do so for a response from MOTU.
His Magicness does show up now and then and we are always glad when he does but it is never a given that he will.
- Kurt Cowling
I haven't tested this just now to make sure, but I seem to remember that loaded chunks had the pitch automation turned off on audio tracks. Try checking that pitch automation is switched on for the imported tracks and even try toggling it on/off. This is accomplished by the VERY small "p" in the sequence window.
DP 11.1, Monterey, 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere 2, Trilian, Stylus RMX, EZ Drummer 2, MachFive 3.11, Real Guitar2, Real Strat, Sample Modeling trumpet, saxes, trombone, Fr Horn/Tuba. Audio Modeling clarinets, double reeds, flutes, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX8 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
Thanks Kurt
But after further tests, I believe it's a buggy DP file.
I'm going to attempt to rebuild the project in a new file and hopefully correct this issue.
Time consuming and frustrating… posting.php?mode=reply&f=1&t=61980#
