No audio after using DP9 bounce
Re: No audio after using DP9 bounce
Currently, in DP9, BTD does not get all (any of?) the crossfades, unless someone has found a workaround to trick it into doing so. There may be other problems as well, such as note dropouts or something. It used to be dead-on accurate. Not now.
We're hoping for a fix in 9.1. MOTU is aware of the problem.
Shoosh
Shoosh
Me too, Kass. Sample-accurate, as a matter of fact -- every single time!kassonica wrote:I've always find B.T.D extremely reliableDavid Polich wrote:Real-time mixdown is your friend. Do you know how to do that? It's way more reliable than
Bounce-to-Disk.
Yeah, but you're back on DP 7.24 — a great version, if your signature is correct. In DP9, you would find it otherwise if you've got fades.Tritonemusic wrote:Me too, Kass. Sample-accurate, as a matter of fact -- every single time!kassonica wrote:I've always find B.T.D extremely reliableDavid Polich wrote:Real-time mixdown is your friend. Do you know how to do that? It's way more reliable than
Bounce-to-Disk.
- buzzsmith
I've been doing real time mixes for the past 4-5 years. Maybe I'm just "old school" but it is my preference!David Polich wrote:Real-time mixdown is your friend. Do you know how to do that? It's way more reliable than
Bounce-to-Disk.
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- kassonica
I wasn't aware that this was one of the issues in DP9....Shooshie wrote:Yeah, but you're back on DP 7.24 — a great version, if your signature is correct. In DP9, you would find it otherwise if you've got fades.Tritonemusic wrote:Me too, Kass. Sample-accurate, as a matter of fact -- every single time!kassonica wrote:
Same here.kassonica wrote:I wasn't aware that this was one of the issues in DP9....Shooshie wrote:Yeah, but you're back on DP 7.24 — a great version, if your signature is correct. In DP9, you would find it otherwise if you've got fades.
- kassonica
I'm just going to wait to get get 9 till they sort out all these issues...
- Timeline
Anyone know when fixes are coming for 9? I was thinking about finally updating but it seems its not all worked out with the latest Mac OS. 10.11.4.Shooshie wrote:Currently, in DP9, BTD does not get all (any of?) the crossfades, unless someone has found a workaround to trick it into doing so. There may be other problems as well, such as note dropouts or something. It used to be dead-on accurate. Not now.
Shoosh
Fixes would come with the next version and as usual, only MOTU knows when that will be.Timeline wrote:Anyone know when fixes are coming for 9? I was thinking about finally updating but it seems its not all worked out with the latest Mac OS. 10.11.4.
I've gotten around it by recording real-time to another track. Then the resulting soundbite can be bounced as an MP3 or whatever. It's a pain in the you-know-what, but at least it's doable. It's only fades that get dropped, as far as I know. A simple soundbite will give you no trouble.kassonica wrote:I'm just going to wait to get get 9 till they sort out all these issues...
Shoosh
MOTU support say they have successfully used the BTD command, so I'll try it again. I was going to work around the problem by playing the original tracks with the plugins inserted out of my 112D's AES or ADAT out into my Roland VS2480, then drag the audio phrases to where I need them.
Mac Mini 2018 - 8GB RAM, 3.6 GHZ Quad Core, 128GB SSD
External 2TB NVME TB3 SSD, External 1TB SSD (OS recovery), External 500GB TB/USB SSD (Time Machine backup)
MOTU 828es
Digital Performer 11, UVI Falcon.
MOTU 828es
That statement needs clarity.wilkinsi wrote:MOTU support say they have successfully used the BTD command...
I can successfully use the BTD command, too. But not if I have track fades and crossfades in the mix.
It will still bounce to disk, but it does not use the fades.
This never happened to me before DP9.
It was my understanding that MOTU knew about this and was fixing it. If they are saying the above, that's bad news. That means they are denying there is a problem, or they have not yet been convinced of its existence. I was certain that they knew about it. Now I don't know. Crap. I guess I'll call them tomorrow and try to get the whole story.
Could someone else chime in here and help me out? Am I the only one who has experienced this? Is this a real bug or just some anomaly on my system? I could have sworn I've seen threads about this in the recent past.
- Timeline
Sh...
When you bounce do you get pops where some crossfades used to be in 9? I think i have heard this in 8 too but I blame it on insufficient CPU capability for the size of project I'm bouncing. Is that wrong?
Upgrading to 12 core 3.46 Westmere and fast (1333) ram hoping that clears it up for me. Will get the tray back Friday actually.
If the fades were covering pops, as in a junction between soundbites, then yes, you'd hear pops. Or rather, you'd hear the lack of fades. It's as if the bounce "playback" isn't programmed to run the fades. They're just irrelevant during the bounce.
I'm sure it's just a programming oversight, as in there's a flag that needs to be set or something like that. Someone just forgot to turn it back on after working on it, or... who knows what?
- Timeline
Right. got it. Thnx
