i have one particular project that gets this very odd alert when i open it. it only happens the first time i open the project after any kind of quit or restart of dp. i can dismiss the alerts and everything works fine. the project was created on a laptop with uad twin, and now is being edited/mixed on my main system, iMac with uad apollo. since nothing actually crashes or becomes unstable or unusable, it's not really a problem, but i thought it was odd enough to be worth posting. will send to motu.
strange alert
strange alert
27" iMac 4.0GHz (late 2015), 32G RAM, OSX 10.13.6, DP10.01, UAD Apollo Duo TB, MTPAV USB (also 2021 14" MBP M1 Pro, 32G RAM, Apollo Twin Duo TB)
Re: strange alert
Just to throw this up as a potential fix:
You could try starting a new project and importing all the chunks from this project into the new one. Just to see of the project file might have some minor corruption.
Re: strange alert
First thing to try.stubbsonic wrote:Just to throw this up as a potential fix:
This is an OS alert, not a DP error. Something is trying to load that can't. You can usually open Consoe.app to see what it is. Try the above suggestion first.
Re: strange alert
thanks, i'll try importing or loading - clearly the first thing to try. also thanks for the reminder it's a system warning, clear from the window attributes...will report back on results. although it's not causing any obvious immediate trouble, it would be better to clear it from happening at all, of course.
Re: strange alert
test!
