mixer track without fader knob
Opened a project yesterday and in the mixer I had an aux track with no fader knob on the slider. Every other track had a knob. The only thing different between this track and the others was this aux track was not routed to anything. When I made a legitimate routing for the track output the knob came back.
Is this normal?
Is this normal?
Re: mixer track without fader knob
I believe that is the normal behavior , yes.
Yes, it is normal.
Thanks for the replies. With all the issues going on with DP 9.02 I wasn't sure if this was one of them, a problem with my system or just normal.
- daniel.sneed
Just in case, AFAICT, disabled tracks do not have a fader button.
dAn Shakin' all over!
The theme you use can have an effect on the appearance or existence of mixer knobs.
Using None More Black.bayswater wrote:The theme you use can have an effect on the appearance or existence of mixer knobs.
