Either 9.02 or latest audio-midi drivers BREAK VE Pro Sync
- toodamnhip
I updated to the latest motu audio and MIDI drivers today, (V 1.6 68717) ,and VE Pro no longer syncs with DP when VE 's buffers are set above "none”.
Can anyone confirm this?
The system was working perfectly before the install so it has to be the new drivers. I then re installed the OLD drivers and VE Pro is still not working right with buffers above “none” bing out of sync.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Re: MOTU’s latest audio or MIDI drivers BREAK VE Pro Sync
Hey 2DH, are you running VEP on the same machine as DP?
- toodamnhip
Yes.Killahurts wrote:Hey 2DH, are you running VEP on the same machine as DP?
I am now uncertain whether or not it was the new driver updates or if it was the 9.02 update itself. Either way, Ve pro is now broken and wasn't before
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Maybe you could reinstall VEP. They have a new version that came out just a few days ago.. might fix it?toodamnhip wrote:Yes.Killahurts wrote:Hey 2DH, are you running VEP on the same machine as DP?
I have the newest 9.02 DP, and the newest version of VEP appears to be working fine.. sorry, I'm not willing to install the new MOTU drivers to find out if that's what it is..
- toodamnhip
The issue occurred in both versions of VE Pro, the newest and the one before.Killahurts wrote:Maybe you could reinstall VEP. They have a new version that came out just a few days ago.. might fix it?toodamnhip wrote:Yes.Killahurts wrote:Hey 2DH, are you running VEP on the same machine as DP?
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Re: Either 9.02 or latest audio-midi drivers BREAK VE Pro Sy
Guess that leaves the drivers for you then. Does the driver have an uninstall? It may be that the only way to install the old drivers is to wipe out ALL the driver software, then start clean.
- toodamnhip
I don’t know if there is an un install.Killahurts wrote:Guess that leaves the drivers for you then. Does the driver have an uninstall? It may be that the only way to install the old drivers is to wipe out ALL the driver software, then start clean.
I have posted at Vienna and will put up a tech link at MOTU.
Last tech link was never responded to.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
