I changed the Time Formats setting to “Frames” for a second to check something and then back to “Measures.” When I returned to the sequence window to continue working, all of the tracks were gone, but the track FOLDERS were still there — just empty. Only the empty track folders are available in the Sequence window's Track Selector.
All tracks AND their folders ARE visible (along with all soundbite information) in the Tracks window.
Finally, playback in either the Sequence OR Tracks window works fine.
Does anyone have any idea why the track data won’t display in the Sequence window?
Tracks Not Visible in Sequence Window
MacBook Pro 2.5 GHz Quad-Core Intel i7/16GB, OSX 10.14.6, DP 10.1, MOTU 896mk3
Re: Tracks Not Visible in Sequence Window
Are the Track Overview and Sequence Editor Windows of the same (active) Chunk?
Frank Ferrucci
http://www.ferruccimusic.com
I don't know if the View Filter applies to this situation, but I'd check it out, just in case.
