assign multiple tracks to MIDI inputs
anyone else finding that the Track Assignments command for assigning inputs to multiple MIDI tracks is not working? if i select a number of MIDI tracks, and use the command to try to assign them all to the same or consecutive MIDI inputs, the MIDI input assignment of the tracks does not change.
27" iMac 4.0GHz (late 2015), 32G RAM, OSX 10.13.6, DP10.01, UAD Apollo Duo TB, MTPAV USB (also 2021 14" MBP M1 Pro, 32G RAM, Apollo Twin Duo TB)
Re: assign multiple tracks to MIDI inputs
Yep. broken here as well. tech link sent.
thank you!
Hmmmm... seems to be working ok here.
Just to be clear, Tracks Assignments under the Studio Menu, MIDI input assignments only. Odd that it fails exactly how he described for me as well? Luckily in my case MIDI inputs need to be assigned by hand and not bulk, so it's no big deal to me...MIDI Life Crisis wrote:Hmmmm... seems to be working ok here.
Are you running AUs as your primary plug in? running VST here.
VSTs here, but I didn't have anything but Kontakt instantiated. It just works.
Noting that changing multiple MIDI inputs with the Track Assignments window is still broken here.
Another tech link sent.
- Primary DAW OS: Windows
Could you achieve what you need with "Remap MIDI devices?"
