Hi all
I'm having an issue with chunks and new sequences.
In the chunks window, I duplicated my current sequence as I want to do a remix but keep all the tracks, automation and processing in place.
The sequence copies over, however when I click on the mixer board form sequence window, it jumps back to Seq-1. If I go to sequence window, my new copied sequence is no longer there. The chunk has the blue arrow selected, however trying to use any other window will make it revert back to seq-1 thereby prohibiting any work...
Any advice much welcomed, G
Issue with chinks/sequences not working
- Studio Llama
Re: Issue with chinks/sequences not working
I'd start by deleting all plists (with DP NOT running at the time) and repairing permissions unless you're on El Cap. If that doesn't work, I'd reinstall DP.
OTOH, it could be a bad DP file so if you haven't already done so, try it in a new project. If it works then the file is bad and you should try to salvage anything you can via LOADING into the newer project or otherwise exporting your MIDI and audio data.
