Slate FG Bomber - anyone having issues?
This is a question for those (probably) few who own a subscription to the Slate Mix/Mastering bundle and who have downloaded Slate's new plug-in, the FG-Bomber.
I'm seeing reports on Gearslutz that the VMR (Virtual Mix Rack) Installer, which now includes the FG-Bomber, is "hanging" Digital Performer. I am not experienceing any problems with either VMR or
the FG-Bomber, is anyone else?
Any replies appreciated - thanks.
http://www.davepolich.com
Re: Slate FG Bomber - anyone having issues?
The demo is working fine here.
Mac Pro 2x2.4 quad core /24 gb ram/OS 10.13.6, Dp 10.13, MTP AV, /UAD 2, KOMPLETE 12, Stylus RMX, SD 3.0, EZ Drummer 3, A&H ZED R 16.
I purchased the plugin, and it works fine for me.
- Gravity Jim
No problem here. VMR A-OK.
Jim Bordner
- audiobox
This should probably be in one of the DP 9 threads...
I know better, but I installed Slate Raven 3.0, Slate VMR with Bomber and DP 9.01 one after another. Uh huh. I knew I was in the stink trench when DP crashed and complained it was its own parabundle EQ that was the problem. Removed that MAS plug, but there were other crashes for no identifiable reason. Much permissions repairing, preferences trashing, removal and re-installing of all concerned.
I could start a new project and insert multiple Slate VMRs. I could open an old project if it was small, like a VO edit session with just a few plugs and a lot of edits, but no big music mixes with mucho plugs. Spinning Pizza of Death forever. Yes, the VO projects had no Slate plugs. Yes, the music projects had many. I removed everything I could find and attempted to revert/re-install earlier iterations of Raven & VMR + DP 8.07. No joy. Something was pranged deep in the gears.
Two days later, I've got a clean install of OS 10.8.5 on a partition with DP 8.07 installed and all plugs except Slate loaded. I opened one of the music projects and DP said, "Dude! Where's the Slate plugs?" I hit OK and bing, there's the project. OK so far. Today, I'll archive this system as is, then I'll try installing the newest VMR. If that works, I'll install Raven 3.0. If that works, I'll erase the old system and migrate the new one to the SSD. After reading about some of the 9.0.1 glitches in various threads here, I think I'll rejoin v.9 a few iterations down the road. It's just not worth it for floating plug windows.
Thanks for all the replies.
I worked all day yesterday on a project with multiple instances of Slate's VMR and FG-Bomber.
No issues at all.
It's a great plug-in, btw.
No issues at all.
- cbergm7210
After I installed the latest VMR 1.1.0.4, attempting to load previous projects with 30+ tracks that had VMR on them would result in indefinite beach balling. Reinstalling the previous version fixed the issue, but obviously prevents me from using Bomber. (So my issue is with the latest VMR, not specifically Bomber.)
After doing some testing with the latest 1.1.0.4, basically the more tracks added to DP with an instance of VMR (with modules loaded, not just the empty rack) the more DP bogged down to the point of hanging indefinitely.
Basically, can all of you guys confirm that you are able to successfully work with 1.1.0.4 with, let's say, 40 tracks that have VMR loaded with several modules in each? With 1.1.0.4, I can make a single track loaded with VMR, start duplicating the track, and by the time I get to around 16 or so, DP starts bogging down, and then eventually hangs at 32. With 1.0.13.1, I can duplicate tracks that have VMR on them indefinitely, going into the hundreds instantly, with no issues.
Movie:
Movie:
http://www.rfjmusic.com
- audiobox
cbergm7210 wrote:After I installed the latest VMR 1.1.0.4, attempting to load previous projects with 30+ tracks that had VMR on them would result in indefinite beach balling. Reinstalling the previous version fixed the issue, but obviously prevents me from using Bomber. (So my issue is with the latest VMR, not specifically Bomber.)
I have had your experience exactly. I just finished doing a clean install of OS 10.8.5 and DP 8.07 on an empty partition. I installed all plugs except Slate VMR. I opened an old project with many instances of VMR and DP warned VMR was missing, I clicked ok and the project opened and was fine. I installed VMR 1.1.0.4 and the project hung. I installed VMR 1.0.13.1 and the project opened and was fine.
If I open a new project or old project with no VMR, as you say, v 1.1.0.4 will work until more than ten instances are installed, then things bog down in a hurry as more are added.
I'll email both MOTU and Slate support tomorrow with this info.
- cbergm7210
Fantastic. I've been in touch with Slate support about this, so indeed contact them as well. It is giving Bitwig users problems also so hopefully they will chase this down quickly.audiobox wrote:cbergm7210 wrote:After I installed the latest VMR 1.1.0.4, attempting to load previous projects with 30+ tracks that had VMR on them would result in indefinite beach balling. Reinstalling the previous version fixed the issue, but obviously prevents me from using Bomber. (So my issue is with the latest VMR, not specifically Bomber.)
I have had your experience exactly. I just finished doing a clean install of OS 10.8.5 and DP 8.07 on an empty partition. I installed all plugs except Slate VMR. I opened an old project with many instances of VMR and DP warned VMR is missing, I clicked ok and the project opened and is fine. I installed VMR 1.1.0.4 and the project hung. I installed VMR 1.0.13.1 and the project opened and was fine.
If I open a new project or old project with no VMR, as you say, v 1.1.0.4 will work until more than ten instances are installed, then things bog down in a hurry.
I'll email Slate and MOTU tomorrow and give support this information.
There were some issues with the first version of the new release of VMR which contained FG-Bomber. I believe those have been addressed. You can email Slate tech support for further info.
For information on contacting tech support, go to:
http://www.slatedigital.com
- cbergm7210
I've had a dozen email exchanges with Slate support about this issue. There is no resolution thus far.David Polich wrote:There were some issues with the first version of the new release of VMR which contained FG-Bomber. I believe those have been addressed. You can email Slate tech support for further info.
- audiobox
It's probably worth noting, since it isn't in my sig, that cbergm7210 and I both have Mac Pro 2.66 octos with 16 or more GB RAM, OS 10.8.5 and DP 8.07. Seems like a pretty generic setup to me but, in any event, Slate support has all the info and I'm sure they'll chase this bug down.I've had a dozen email exchanges with Slate support about this issue. There is no resolution thus far.
[quote="cbergm7210"]After I installed the latest VMR 1.1.0.4, attempting to load previous projects with 30+ tracks that had VMR on them would result in indefinite beach balling. Reinstalling the previous version fixed the issue, but obviously prevents me from using Bomber. (So my issue is with the latest VMR, not specifically Bomber.)
/quote]
I'm having zero issues with VMR or FG-Bomber, but then I'd never put 40 instances of any single
plug-in on a project. A the most, I might have 5 instances of VMR.
/quote]
- cbergm7210
The CS eq's are my go-to eq so at the very least use that on all tracks. If you or one of the other kind fellows would take 60 seconds and trying to put VMR with modules on 30 tracks or more I'd be curious to see if you had similar results.David Polich wrote:cbergm7210 wrote:After I installed the latest VMR 1.1.0.4, attempting to load previous projects with 30+ tracks that had VMR on them would result in indefinite beach balling. Reinstalling the previous version fixed the issue, but obviously prevents me from using Bomber. (So my issue is with the latest VMR, not specifically Bomber.)
/quote]
- cbergm7210
I made a temporary boot drive, updating my Mac OS from 10.8.5 Mountain Lion to 10.10 Yosemite. The latest version of VMR works fine on this OS, so it looks like there is a problem with OS 10.8.5 Mountain Lion and the latest VMR release.
