I have a MIDI file set in Apple's Finder to open using DP9.
Why is it that when i double click that MIDI file it will not launch/open with or in DP 9 ?
Or, if i have DP 9 set up for a new project why does drag drop not work ?
Help and comments very much appreciated.
DP9 and MIDI files [RESOLVED]
Mac OS: Mojave
Re: DP9 and MIDI files
Right-click mouse on MIDI file and select your favorite app or.. get info and in "open with" pop up menu select DP as default app for MIDI filesmidiw wrote: Why is it that when i double click that MIDI file it will not launch/open with or in DP 9 ?
I'm on DP8 and this feature works perfectly...in DP 9 must also work fine (has your file a standard ".mid" extension?)midiw wrote: Or, if i have DP 9 set up for a new project why does drag drop not work ?
DP 10.11 || iMac 2019 5K ||i9 8core 3.6GHz|| 64 GB RAM|| macOS 11.5.1
RME AiOPro || Softube Console 1 ||
buhardilla
Thanks, that was my problem. Works like a charm in DP9.get info and in "open with" pop up menu select DP as default app for MIDI files
