Tempo slider change with mouse scroll wheel-DP 9
cbergm7210
Post by cbergm7210 »
Up until DP 9 the mouse scroll wheel would change the tempo slider value by 1, now it is by 10. Am I missing a preference setting somewhere, or was this a new change in DP 9 in general?
Thanks, fellows.
http://www.rfjmusic.com
Re: Tempo slider change with mouse scroll wheel-DP 9
I can't confirm this. Still by ones here. I'm using BetterTouchTool with an Apple Magic Mouse. Are you using any kind of mouse hacks?
cbergm7210
cuttime wrote:I can't confirm this. Still by ones here. I'm using BetterTouchTool with an Apple Magic Mouse. Are you using any kind of mouse hacks?
No hacks. And I can boot into DP 8 and it still works in increments of 1 there, which is great for fine tuning tempos quickly as opposed to typing in values.
Tesionman
Post by Tesionman »
Yes, I noticed it too.
Don't know why they changed this. :shake:
I do prefer by increments of 1.
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
Phil O
Post by Phil O »
You can click on the number field and drag up or down. If you click to the right of the decimal point it changes the fractional part (mantissa) and if you click to the left of it it changes the integer part by 1. Not the same, I know, but a workaround.
Phil
I'm seeing the same as Phil. And using the wheel without clicking the changes are in 1s, not 10s.
cbergm7210
Thanks for the workaround, Phil-O. My screen is almost 4' from the mix position so these small windows are difficult to see. Hovering the mouse pointer and rolling the wheel is very easy to do without having to actually see the tempo numbers IOW.
cbergm7210
After 10 hours mixing...
Phil O
Post by Phil O »
Ah, yes. Didn't recognize you with the glasses.
BTW, I've got the magic mouse with the little scroll ball. The slightest movement of the ball makes the tempo jump 20, 30, sometimes 40 ticks. I can still get increments of 1 in DP8.
Phil
Phil O wrote:I've got the magic mouse with the little scroll ball. The slightest movement of the ball makes the tempo jump 20, 30, sometimes 40 ticks. I can still get increments of 1 in DP8.
Phil
I was having that problem, along with wild zooms, etc., with a few Apple pointing devices using DP 8. It all cleared up with OS 10.10. Now with DP 9 the rapid movements and zooms are back, except for the magic trackpad, which seems to have kept its cool. I have to attribute this mostly to DP -- various other applications have remained stable on this matter throughout version and OS changes.
cbergm7210
We'll chalk it up to another DP 9 bug that hopefully gets fixed in .01
