Send levels Bug in DP9
Hello, I found a new bug in DP9
When you freeze a VI that have a send output, the freezed track doesn't clone the original aux send setting! I mean, the aux send on the freezed channel appears full leveled!
This is annoying because you have to manually set your sends levels on the new freezed
8.07 64bit, Spire, Nexus, Fab FilterDiva, Gladiator, Nexus, Sylenth, Stylus RMX, Live 9, Reason 6.5, Komplete 8, AD Keys, AD Drums, Geist, Ivory, Waves 9 Mercury, Sound Toys, Fab, VEPro, Reason, Live, UAD2, x3 2408mk3, PCI424, MAC PRO Dual 3.46 Ghz 12 core Intel Xeon, Memory: 64gb ram, MAC OS X: 10.8.6
Re: Send levels Bug in DP9
This is a big issue to me, sometimes I have 15 virtual instruments, each with diferent "send level" settings and a like to freeze them all, with DP8 all the sends levels remain at the same place on the Freezed tracks, DP9 set all the send levels at the max level, and I have to manually re-set one by one.delcosmos wrote:Hello, I found a new bug in DP9
I can't deal with this, sadly I'm going back to DP8.07. Hope Motu fix this on the next update.
- FMiguelez
Also, and I had already mentioned this in another thread, when one disables a track, then the send pan defaults to <32. It comes back to the original setting when reenabled, but it looks wrong, theres' no reason for it, and it causes potential confusion (as it happened to me). IT is annoying to me because I am enabling/disabling tracks all the time...
It's like if all tracks' volume faders went arbitrarily to --6.3 dB when disabled. It's unacceptable.
I'm finding lots of little bugs in DP9... I hope they fix them soon
I can hear you!FMiguelez wrote:Also, and I had already mentioned this in another thread, when one disables a track, then the send pan defaults to <32. It comes back to the original setting when reenabled, but it looks wrong, theres' no reason for it, and it causes potential confusion (as it happened to me). IT is annoying to me because I am enabling/disabling tracks all the time...
And... Theres something else, I used to have 32 "dumy" tracks at the begining of my session to control my two SSL Sigmas, I used to disable those tracks because On some of them I don't need automation. In DP8.07 I was able to still move the faders on those disabled tracks, now with DP9, if you disable a track the fader disappears! So I can't set the level of those "Dumy" tracks unless I enable the channel, but 32 enabled tracks put more strain on my CPU, but anyway, I can live with this, but I really can't live with the "send levels bug".
Going back to DP8.07, hope nothing was broken after installing DP9.
I'm not getting this. Did you report it? Could MOTU replicate it?FMiguelez wrote:Also, and I had already mentioned this in another thread, when one disables a track, then the send pan defaults to <32.(
- FMiguelez
I admit I have not done such productive thing. I´ve just bitched about it so farbayswater wrote:I'm not getting this. Did you report it? Could MOTU replicate it?FMiguelez wrote:Also, and I had already mentioned this in another thread, when one disables a track, then the send pan defaults to <32.(
I´ll report it now.
BTW, the same happens with the sends´ volume pots... when the track is disabled, they all go to minus infinity. When re-enabled, they go back to whatever setting they had when set when enabled. At least visually, it´s scary.
I can confirm this.FMiguelez wrote:Also, and I had already mentioned this in another thread, when one disables a track, then the send pan defaults to <32.
Yes, I am seeing that. I suppose it's a response to the frequent complaint about them defaulting to 0 db. Whatever they did, looks like it's linked to the enabled status. I'd rather they stay where I put them.FMiguelez wrote:BTW, the same happens with the sends´ volume pots... when the track is disabled, they all go to minus infinity. When re-enabled, they go back to whatever setting they had when set when enabled. At least visually, it´s scary.
- FMiguelez
Perhaps, but then, if it is, is half-implemented, and not really what we wanted...
What we want is that, when we create a new send, its volume does not default to 0 but minus infinity. As far as I see, they still come at 0, but with the added non-sense of showing different values when disabled.
What I love, and it´s the reason I ONLY use the Plasma theme, is that, when sends are unsigned, nothing appears there, so it reduces visual clutter greatly, since you only see what you actually assign. THAT is nice, but not that contradictory behaviour.
Please tell us what to watch for.
Ha ha ha, sorry for my poor video.
I wanted to show that after freezing the track, the sends on the new track doesn't match the original send levels.
Thanks. The video was fine, I just didn't know which specific bug was being shown.delcosmos wrote:Ha ha ha, sorry for my poor video.
Cool! I hope they fix this.
I'm back to my trusty DP8.07, everything is working great now and I can even open the new MW fet plug in!
Best regards.
Best regards.
- mhschmieder
Does it happen every time, for those who are seeing this problem?
There are some Mixer window quirks that I'm seeing when tracks are disabled, but only the first time. Toggling the track enablement (I think I did this in the Tracks Overview) clears it up.
Maybe something similar afoot here.
The main thing I observed was volume sliders at zero when a track is disabled. As I only enable tracks I'm mixing or recording, and like to do audits to make sure things haven't moved unintentionally, I was sufficiently upset by this new problem that I tried to reproduce it and also to see if I could fix it through workflow choices.
I wonder also if this is related to not following the suggestion (which I just learned through the forum after shutting down my DP9 session) of taking a snapshot initially?
