Geist vst not working right on DP8.07
Has anyone had any problems with VST's that they haven't had before? I haven't used it in a while so I'm not sure what I may have changed, like updating DP or what, but I pulled out the VST version of Geist today and while the plugin loads and seems to work, when hitting play it outputs nasty distorted noise. AU version works fine (but does not support MIDI out). The VST version works fine in Reaper, but does not work on DP8.07.
Thoughts?
Thoughts?
Re: Geist vst not working right on DP8.07
It's working here in 8.07...
as a VSTi of course.
Oh the fun of figuring out now what is causing your issues.
- BKK-OZ
I gave up on Geist about the same time I gave up on BPM (MOTU/UVI), so sorry I can't help. It was always a bit flakey in DP, which is one of the reasons why I stopped using it.
I use Maschine, and apart from a bug with window scrolling in DP yet to be fixed by NI/MOTU (see my other posts on that), I have found it to be worth the investment of time and money. (I just have the Micro controller, and the full, latest, studio).
Cheers,
BK
- M Kaku
BK
- M Kaku
man. Nobody on Fxpansion forum has any idea about this either. The weird thing is the VST version works great on Reaper, so I guess nothing wrong with the VST, and I know I used to used it in DP too... arggg...
I'd love to mess with maschine, but its kind of pricey I guess and I'm not enough of an MPK head to make the purchase. I got Geist on sale and it does the job well, the only thing is MIDI out only works in the VST version.
- BKK-OZ
Maschine is a big step up from both Geist and BPM. It took me awhile to get used to its quirky way of working, but it is a very versatile and fully functioning tool. I often use it stand-alone as a scratch pad, because it is a fully-fledged host in its own right. I barely use the controller - preferring to use the software interface for almost everything, hence sticking with the (first generation) Micro controller. Lots of good library material too.
Sorry I can't help on Geist. Have you contacted Fxpansion's support?
I always found them to be terrific.
Cheers,
BK
- M Kaku
BK
- M Kaku
If I was doing more beat production on a regular basis I would totally consider it. I keep hearing good things.
calling fxpansion support, what a concept. maybe I will do that. Have been trying the forums first hoping it was something others have experienced too, but doesn't sound like it and I expect it will not be easy to solve
well problem solved, but not sure how. Maybe its related to my SSD drive. The Samsung EVO 840 has some reported performance issues apparently and there is this DOS utility you have to run that somehow resets the drive back to good performance. After I did that, Geist VST seems to work ok. I have no idea if that is what fixed it or just circumstantial. If that fixed it then it would imply that AU has better caching in some way then VST does and perhaps VST version is reading direct from the disk in some way that would be negatively impacted by the SSD problem.
Anyway, problem is resolved.
I will still keep Maschine in mind though, your comments are noted BK...
