troubles with VEP and DP 8
pbaille
Post by pbaille »
Hello,
I've got some playback problem with DP 8.07 and VEP, OSX Yosemite
i've got a VEP server with 5 instances of VEP connected to 5 instruments tracks and 63 MIDI tracks (one for each instrument)
when playing my score the first time everything is fine, but when I rewind and play again, some notes remains stuck on.
When looking closer, it seems that at the moment I hit rewind, DP plays super fast the first bar of my score (without sound) and some notes remains on at this very moment.
As far as I understand it DP records in advance the first bar of my score to avoid playback lag, am I right?
Is there a workaround to avoid this issue?
Does this is the well known "stuck notes" problem?
I've installed the new MOTU MIDI driver but it doesn't resolve anything.
Any help will be greatly appreciated!
thank you
pbaille
Re: troubles with VEP and DP 8
Post by pbaille »
Hi!
I've finally solved my issue, just need to select "All plugins in real time" in preferences/General/Audio Plug-ins !!!
labman
Post by labman »
Generally, we dont see stuck notes unless using the dreaded event input plugin.
