Bounce with Multiple Outputs
Hello!
I'm trying to bounce two tracks with two different output assignments down to one stereo WAV. Is this possible?
The "Bounce to Disk" pop-up menu only allows me to choose one source; consequently, only one track gets bounced to the stereo WAV.
DP 11.31, Mac Studio M2 Ultra, 128GB Memory, Sonoma 14.3.1
Re: Bounce with Multiple Outputs
Change the outputs to the same one. You cannot bounce two outputs to a single file AFAIK. You might bus them but I think you need an "active" output to BTD.
My only issue with changing the outputs to the same one is that I'm running one output 15-dB less than the other. So, the balance between the two tracks will be off.
Can you bus them to an AUX and adjust it there? Then send the AUX to a single out.
OR...
how do I set up Master Faders to control different outputs globally?
that might not make sense in this situation, but I think it might help me.
You'll still need setup an aux track, I think. Have you tried that yet?
I'm not quite sure what to do once the aux track is set up.
Bus the tracks to the aux and set the output to a single output.
