I'm having some VI tracks that won't play the notes I'm clicking on in any editing window even though I have sound enabled. This is making it quite difficult to do any editing! Is this a known bug? Or is there something else I need to do to get this to work? I already tried deleting the VI and re-adding it, quit DP and it worked for a short time then quit again! The VI's I'm using are MOTU's bassline and Toontrack's EZ Keys and EZ Drummer2.
Thanks so much for any help!
No Sound in Edit Windows
Re: No Sound in Edit Windows
This happened to me as well. The fix is easy.
Go to the VI's plug-in GUI. In the little mini menu (upper right) is a setting that says:
"Run this instance in realtime."
Turn that on, and you should be good to go.
That did it! Thank you SO much!!!!
