DAW: DP 8.07 Macbook pro 10.9.5 - VSL EP 5.3.13240
Slave: windows 7 64 bit VSL EP Play 4.2.2
MIDI event input doesn't work with Play installed inside VSL EP meaning I can only use one MIDI port. Tried running it from DP7 as well off a different daw with the same result. Uninstalled reinstalled etc etc Is this me or is this a common problem?
DP + Play+VSL EP = :(
Re: DP + Play+VSL EP = :(
I use several vienna event input in DP together Play instances in VEP and I don't have any problems. I have just followed the VEP manual instructions... sincerely, I don't know how I can help you, because of the communication between DP and VEP through vienna event input was fixed since DP 8.07 was released
DP 10.11 || iMac 2019 5K ||i9 8core 3.6GHz|| 64 GB RAM|| macOS 11.5.1
RME AiOPro || Softube Console 1 ||
