I don't know if this is normal behavior - I set the numeric keypad command keys for the note values to mimic Sibelius - 5=half, 4=quarter, 3=eight, etc. The correct value highlights when I press the corresponding key but when I press a new value the previous values does not release. So if I press 4, the quarter note turns on, and then if I press 3 the quarter remains on and the eighth also turns on the value entered is a dotted quarter.
If I tap the current value before tapping a new value it will release.
Are you supposed to double tap to release a value?
Any ideas?
Step Input Numeric pad anomoly
