Exporting specific MIDI tracks (+ tempo/conductor) to MIDI?
I can't figure out how to export a MIDI file, but only the tracks I select. If I have a template with 100+ tracks and a particular cue only uses 6 of them, I really wish I could just somehow select those 6 (plus the conductor track) and export those to a MIDI file. It seems the only thing I can do is manually delete dozens of tracks first, then export.
Is there a better way?
Re: Exporting specific MIDI tracks (+ tempo/conductor) to MI
Ah! I was still searching through forum posts and hadn't found anything, but I just now did.
Looks like the easiest possible way is to select the desired tracks (or MIDI data), then choose Project > Sequences > Copy Selection to New Sequence.
Before Save As, try turning off play enable for the tracks you don't need.
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
Tried that, disabling MIDI tracks has no effect on what gets exported.
Works over here - are you using Save As or Export?
try Save As.
try Save As.
I did "Save Copy As" then chose MIDI format.
Save a Copy As works OK over here, too.
Are the MIDI tracks outputting to different channels ?
Not just different instruments, different channels.
Oh, I see better what it's doing - all MIDI tracks are exported but only the play enabled tracks have notes.
That won't help you much, sorry.
So, I load up a DP project. I disable all MIDI tracks except for two of them (harp and piano). I go to File > Save Copy As and choose MIDI format 1. That MIDI file has all the tracks (including note data), even the ones I disabled (by clicking the blue "play" triangle).
- Shooshie
You used to be able to drag selected tracks to the finder. It would be a Standard MIDI File format. Don't know if it still will do that or not.
Also, you can drag selected tracks to the Chunks Window. I haven't tested these recently, as of DP 8.01, but I've used these methods many times, I suspect they still work.
You can CMD-drag tracks to the finder, but that results in a MIDI file with just the track. It also may not have the tempo/meter embedded. I'd need to dump 2 or more MIDI tracks to a single file.
I'll just keep using the method I discovered and mentioned above. It works!
- Shooshie
I think if you select tracks, including the Conductor track, and drag them to the Chunks Window, you'll get what you're looking for. Have you tried that? I think you have to drag from the data side of the Tracks Overview Window. If that doesn't work, try the track name side. (not in DP at the moment, so I can't test it for you)
Try Export / Selection as MIDI file
Include Conductor track in the selection
- Shooshie
Yes, as with most things, DP offers you multiple paths to the destination!reedster wrote:Try Export / Selection as MIDI file
shoosh
Aha! Even better. Thanks, I swore I looked at the Export menu, but not closely enough apparently.
