Parameter Error (-50).
Hi,
I work on DP 7.24
Macpro 2.1 Leopard X.5.8.
I backup my DP programs on another external Hard drive.
But when I open the DP program on the external HD and I make some modifications he dont want to save.
And he tel me:
"Macos Error.
Parameter error (-50) Try to save your file on another disk or folder or with a different name."
Please if anybody have an idea to solve my problem let me know.
Thanks a lot.
I work on DP 7.24
And he tel me:
"Macos Error.
Thanks a lot.
MacPro 5.1 6-core 3.33GHz 16GB RAM.
Motu 2408MKI PCIe 424, with Focusrite octopre
Alphatrack.
DP7.24, SD2, Omnisphere 1, Komplete 7,Ethno.1.0.1,Styllus RMX 1.8
Alphatrack.
Re: Parameter Error (-50).
I am stuck......
Any advice are welcome.
Thanks again.
Thanks again.
Alphatrack.
Alphatrack.
Repair permissions.
MIDI Life Crisis wrote:Repair permissions.
It's possible that you don't have privileges. Does your User Admin account show up in Get Info on the project folder? If so, does it have Read and Write privileges?"Macos Error.
Lots of threads on this issue.
Thanks a lot for your answer.
I try the repair permission process didn't change.
That's happen only on the DP program are on external Hard Drive but not on DP program are on the internal Hard drive.
Making my research I find that on Motunation:
http://www.motunation.com/forum/viewtop ... 50#p435563
It can be related??
Thanks a lot.
It can be related??
Thanks a lot.
Alphatrack.
Alphatrack.
DP is authorized on the internal drive it is installed on AFAIK. If you move the app to another drive you may well see errors.
Contact MOTU for more info.
You tell us. Is your external HD formatted correctly? Do you have Read and Write privileges to the entire drive?p.pan wrote:Thanks a lot for your answer.
It can be related??
Thanks a lot.
We can't diagnose systems we can't see--only offer suggestions where you can look.
This is a common problem and easily solved.
