Hi all
Apologies for making a new topic for this, I did search but couldn't find an answer. I am trying to set up Rewire to slave Ableton to DP. I have looked around and followed the instructions, downloaded rewire and installed, at least it said installed.
I'm running DP 8.07 and Ableton 9 on Mavericks on a MacBook Pro 2012.
I open DP first, then Ableton, make a aux track, but Ableton doesn't show up as a potential input. Is there any reason why this might happen?
Thanks in advance for any help
Rewire for Ableton not showing up in stereo bundle *SOLVED*
- Studio Llama
Re: Rewire for Ableton not showing up in stereo bundle
Have you restarted your computer since you did this?
Proppellerheads forget this part of the rewire installation. I just had the same issue on this laptop, and installed rewire, quit and reopened DP, nothing. Restarted the computer and DP shows Ableton Live Rewire inputs.
- Studio Llama
Hi Michael
Yes, I tried that, just exploring the possibility right now that it's because Live is 64 bit and I'm running DP in 32 annoying, but if that's the case I may have a solution...
Thanks...
Thanks...
- Studio Llama
Re: Rewire for Ableton not showing up in stereo bundle *SOLV
Right, the issue was running one app in 32 bit and the other in 64. Problem solved, running great now, thanks!
