DP 8.07 crash (solved), Jbridge update and question
tommymandel
Re: DP 8.07 crash (solved), Jbridge update and question
Post by tommymandel »
Thanks, bays.
DP 11.03 12core(5,1): 64GB/10.13.6, two 24i/o's, two 2408mk3's, 4pre, MicroLite-- MBP 2015 16GB/ 2TB 'Blade SSD 10.14.4, Mainstage, Numa C2x, ReMOTE SL -- SupDrmr, 32 Lives, SampleTron,Keyscape,MTronPro,RolCloud,Icarus,Dune,OB-E; Clearmountain Domain,Soundtoys,AdrenaLinnSync, LinnSequencers,Tempest, Montage, JU80, Sledge, Prophet-X, OB-6 V-Synth, s70xs, D-50, TS-10, JD800, Karma, Pa-1x B3, Wurly, Mason Hamlin.
ccrane
Post by ccrane »
bayswater wrote:
ccrane wrote:Fwiw, I believe there are 64bit VST versions of the MDA plug-in bundle.
http://sourceforge.net/projects/mda-vst/files/mda-vst/
I haven't installed them yet but in 2012 I emailed the developer and he told me that the Sourceforge versions were 64 bit.
Yes, they are 64 bit -- at least they will load into DP 8. But like the bridged 32 bit versions, there is no user interface available. So you can't edit any of the parameters.
Thanks for that info bayswater.
