DP 8.0.6 creates soundbites with identical names
In the soundbite list I have two pairs of soundbites with identical names. How is this possible? They have different creation dates and different length as well. Each pair comes from the same file.
Windows 10, DP 11
https://www.youtube.com/channel/UCOI37x ... 8vAQJwNm_A
Re: DP 8.0.6 creates soundbites with identical names
I've always been able to have identical track names on different soundbites here (not just this DP version). Always requires a little extra care, but hasn't been a huge problem for me.
I just find it confusing when I'm about to choose between them, comparing one to another and so on. Don't you?
Still I can't see why DP does this, if it's not I who have given them the same name by mistake. It's possible but I doubt it.
Windows 10, DP 11
There must be some unique identifier. Is that accessible?
Can you "show in Finder" and confirm they are different files? If not, I'd select the duplicates and remove from list, then delete via the Finder. If they point to the same file, I'd just remove from list.
How and why they got there is another issue and hopefully a report to MOTU can start the process of sussing that out.
The 'file' name always stays the same, the 'name' should change with each edit iteration.
If you have an edit piece of a very small size, a few samples, it will sometimes have the same 'name' and also never get removed with a 'select unused soundbites / delete' operation.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
