Just discovered a very annoying DP8.06 issue...
FMiguelez
Post by FMiguelez »
I've been working on a voice over where the girl has very accentuated esses. Lots of "sssss" and "shsss".
Every time I time-range select an ssss sound and loop it (to pinpoint the offending frequency with an analyzer and EQ it out destructively), DP seems to go past the boundary of the right side of the loop. By a lot. Almost as if the selection were twice as long. And I can't get it to do it right.
No matter how short or long the loop is, it will never loop around the exact selected range. This renders this workflow useless for me.
I won't be able to update to DP 8.07 until next week, and I don't even know if this new version does this as well.
Is anyone else seeing this in DP8.06 or DP8.07?
supersonic
Re: Just discovered a very annoying DP8.06 issue...
Post by supersonic »
De-essing it automatically is not an option? I have not seen that behavior in 8.06 or 8.07 and I have been editing a lot yesterday. Perhaps you have the grid snap on? I suppose you are picking a very small portion but then again I do that too and so far so good.
Music is movement in silence
FMiguelez wrote:I've been working on a voice over where the girl has very accentuated esses. Lots of "sssss" and "shsss".
I can't remember... is there a post-roll setting in DP anywhere?
FMiguelez
Post by FMiguelez »
supersonic wrote:De-essing it automatically is not an option? I have not seen that behavior in 8.06 or 8.07 and I have been editing a lot yesterday. Perhaps you have the grid snap on? I suppose you are picking a very small portion but then again I do that too and so far so good.
Yes. I had to set an automatic de-esser.
The looped regions were mostly very short (as short as normal spoken esses). The grid was off, so that would't be the reason. And even if it was on, once the desired time- range selection is set, it shouldn't matter, correct?
I'm actually hoping that's the reason I'm having this problem, but I've never seen a setting for post-roll for looped regions.
Tritonemusic
Post by Tritonemusic »
If you use destructive plug-ins, the window that pops up when you "Apply", also has post and pre-roll fields where you can enter an amount in milliseconds.
I'm not sure if that answers your question or not. DP 7.24.
I don't remember the last time I did something like that, so I'm not too sure how it corresponds with any selection you make.
Phil O
Post by Phil O »
FMiguelez wrote:I won't be able to update to DP 8.07 until next week, and I don't even know if this new version does this as well.
It seems to behave the same way in both 8.06 and 8.07. I think there is a minimum time duration for which a loop loops accurately.
I tried this:
With time displayed in SE, started a loop at time 0:00:00.00 and ending at 0:00:00.28.
Placed a short SB with a click at 0:00:00.30.
The loop seems to work properly and the click cannot be heard.
With the loop starting at 0:00:00.00 and ending at 0:00:00.20 and the click at 0:00:00.22, however, the wiper continues past 0:00:00.20 and plays the click at 0:00:00.22.
I don't know of any settings that change this.
There is a work-around if you really need to analyze a very short segment. Copy the segment and paste it to an empty section of the track. Then set the loop over that section. The loop will still be too long, but at least you'll only be analyzing the audio from the segment you copied. It's a PIA, but it will get you the data you're looking for.
Phil
FMiguelez
Post by FMiguelez »
Phil O wrote:It seems to behave the same way in both 8.06 and 8.07. I think there is a minimum time duration for which a loop loops accurately.
I tried this:
Phil!!
I lost track of this thread.
Thank you so much for your reply.
I did a similar test to yours, and you're right. DP appears to have a limit as to how short the looped region can be before exhibiting that behaviour.
In my case, the limit is 250 milliseconds. At 240 ms, it gets past the region range.
I don't know if it's a bug or a DP limitation. But I discovered that if I select Apply Plug-In, and use the Preview button, then there's no limit anymore. The looped range can even be 10 ms 8)
Thank you for taking the time for testing this!
Phil O
Post by Phil O »
No hay problema.
