Hi,
I was wondering if there's a way to create commands for the items in the mini-menus. For instance I've been using the new sound bite folder in the soundbites window mini menu quite often, is there a way to create a command for that?
Thanks!!
Commands for mini menus
- FMiguelez
Re: Commands for mini menus
Check out QuicKeys.
Also, if you perform a forum search, you should get a few recent related threads with more info abot it.
- ziobello
Thanks a lot FMiguelez!!
DP 8.06, Mac OS 10.9.4, MacBook Pro, 2 GHz Intel Core i7, Memory 16GB w/2 Mercury SSD Drives, VE Pro 5.3, Apogee Duet, VRM Box.
Some commands in the Mini menus can be found in the Commands Window where you can assign a keyboard shortcut. E.g. Edit Audio Export Formats appears as unassigned in the Commands Window.
- ziobello
Great, I'll check them out!
