Tab to next/previous note in MIDI editor with audible mode
- ziobello
Hey there,
I'm trying to edit a part in the MIDI editor, and I was wondering if there's a way to move to the previous/next note, without having to click on it, in a way that would make the note audible (in audible mode) just as when you click on it. I noticed that if you click tab you can move to the next note, but it's not audible, and also I don't know how to go back with the tab and some other key.
I also noticed that you can hear the pitches changing when you nudge up and down the note with ctrl-command and the up and down arrows.
Could anyone help me?
Re: Tab to next/previous note in MIDI editor with audible mo
On my rig, Tab doesn't move the note selection forward, but OPTION-TAB moves it backward (to the previous note). Perhaps my Tab key is assigned to something else.
I completely agree though that it would be super handy to have it play the note.
Thanks for reminding me about the nudge up/down. I always drag, but that is handy. However, it is pretty slow/sluggish on my machine-- not nearly as snappy as dragging. Maximum speed to nudge is about 160 BPM. If I hit it multiple times fast, it will walk up at 160 BPM 'til it arrives.
It would also be great if the nudge was responsive. Then I might use it.
The only thing I can think of is to hit Tab (or whatever key you have assigned), then hit Option-Spacebar. That will play the note you just jumped to.
Tab, Option-Spacebar...Tab, Option-Spacebar....repeat as necessary.....
Unfortunately, that's not as streamlined as what you're looking for.
- ziobello
Thanks stubsonic, now my rig does the same thing, tab only works in the sequence window but not in the MIDI editor. In this editor option-tab works for me too, whereas tab toggles the keyboard input of the grid value, and I can't find the last one in the commands to overwrite. I put control- tab for the next event and it works fine.
Thanks Tritonemusic I didn't know option-space bar it works great!
There are a whole bunch of undocumented commands for that kind of thing which you will find in the Commands Window (SHIFT-L).
The particular section which you would find most useful would be the Selections section. Also worth checking out would be Navigation, though I don't think it will select anything for you. Apply keyboard or MIDI triggers to the commands you like the most, and DP will open new vistas for you.
- ziobello
Thanks a lot Shooshie, that's very helpful!
