Hi all !
In DP8 , can I use Mas, Audio unit and Vst plugins at the same time ?
I do see all my plugins in preferences but I can not install the vat ones in the inserts ?
Aramis
Vst plugins in DP8 preferences but ?
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
Re: Vst plugins in DP8 preferences but ?
Yes, you just need to create your own plugin set in preferences and select the ones you want. When you start to select additional plugs, it will automatically create a new set. The all VST or all AU are just defaults.
DP8.06 PT11.2.0 VEP 5.3.x
Thank you very much !!!!!!!NazRat wrote:Yes, you just need to create your own plugin set in preferences and select the ones you want. When you start to select additional plugs, it will automatically create a new set. The all VST or all AU are just defaults.
