I'm about to install Komplete 9. It's a big install, and I'm trying to time it starting early in the morning, so that when I get to the error (I would be very surprised if there were not one), I can call NI support during business hours with my fully charged iPhone, ready for crunchy distorted on-hold music.
Any other advice?
Komplete 9 Install Failure
Re: Komplete 9 Install Failure
That is a good plan. I installed K9 on two different Mac Pros without an encountering any issues, so hopefully you will get through it smoothly.Killahurts wrote:I'm about to install Komplete 9. It's a big install, and I'm trying to time it starting early in the morning, so that when I get to the error (I would be very surprised if there were not one), I can call NI support during business hours with my fully charged iPhone, ready for crunchy distorted on-hold music.
Any other advice?
- BKK-OZ
Make an offering to whatever deity floats your boat.Killahurts wrote:Any other advice?
The last two times I did NI upgrades, much gnashing of teeth and wailing was involved before I got functional again. Permissions checking and database rebuilding was required, as well as some additional downloads.
If I was in that position again right now, I would have a quick skim of the NI forums to see if there is anything afoot, I would make sure NI service center is up to date, that Time Machine was in a state read to roll-back, and well... I would pray.
Good luck brother!
Cheers,
BK
- M Kaku
BK
- M Kaku
Well I got all the way to the end, "disc J" I believe.. without a hitch. At the end of disc J, a message came up that said the installation had failed. I laughed out loud, because it was Friday, and too late to call support.
I found where it installed the content, it's all there, apparently. Trouble is, it's in a folder on my sample drive called HD>Users>Shared>
I tried to remove it and put it into a "Komplete 9" folder I made, but then I can't access the content from any of the libraries, like Kontact, Battery, etc.
I gotta figure out if there's a way to create a proper folder and redirect all those instruments to it, without having to reinstall.. I don't if it can even be done.. maybe I'm stuck with that path.
- BKK-OZ
I think you are experiencing similar problems to those I encountered - NI doesn't really seem to like it if you want to store your libraries anywhere other than the default locations.
Can you open up Kontakt in stand-alone and do a db rebuild?
Cheers,
BK
- M Kaku
BK
- M Kaku
That's what I'm going to try tomorrow.. I'm a Kontakt idiot, so I have to look up how. But K5 is the most important thing.BKK-OZ wrote:Can you open up Kontakt in stand-alone and do a db rebuild?
My primary sample drive died in the summer, in the middle of an album project. Had to replace the drive. I still do not have a high tolerance for endless rerouting of VI's to their content..
