Seeming for now reason DP stops seeing MIDI input from my MTP AV, until I connect another MTP AV.
(I have a few MTP AV units.)
DP stops seeing MIDI from the MIDI keyboard connected to the MTP AV. Until I connect another MTP AV and then DP sees MIDI information from this other unit.
Audio MIDI setup seems right.
It seems like my Audio MIDI Setup is corrupt or something - and connecting another MTP AV unit seems remedy the problem. But the problem comes back - and I connect another unit and it is good again.
Any ideas?
Dean
DP stops seeing MTP AV, until I connect another MTP AV
Re: DP stops seeing MTP AV, until I connect another MTP AV
When was the last time that you changed the C2032 battery?
Not in recent history. I will try that.
Dean
Dean
