Hello!
I draw in my volume automation via the Sequence Editor. After selecting volume controllers amongst several tracks, is there a way to increase and/or decrease volumes by percentages all at the same time? Or by a set amount of dB? I know I can do this in with MIDI controllers. What about with audio?
Aaron
Collective Volume Automation
DP 11.31, Mac Studio M2 Ultra, 128GB Memory, Sonoma 14.3.1
- Dan Worley
Re: Collective Volume Automation
Brilliant! Thanks so much!!
- Dan Worley
In case others stumble across this, and since it has caused some confusion in the past: To attenuate, one must enter negative numbers (like, -1.25) in the "Add to all values" field.
DP10.13
Very good point!Dan Worley wrote:In case others stumble across this, and since it has caused some confusion in the past: To attenuate, one must enter negative numbers (like, -1.25) in the "Add to all values" field.
Works the exact same with MIDI velocity changes, etc. as well.. one of the things DP is famous for.
