Hi, all.
I'm having trouble searching the forum and internet for the answer to this question because I'm just not sure how to phrase it correctly. (So I'm sorry if this is a double-post)
When editing MIDI or WAV files, my click-and-drag is, by default, automatically moving everything into the given tempo... is there a way to shut that off so that I may freely drag sounds to where I please? (Manually making a ritardando by dragging files away from each other, for example.)
Turning off the "auto" tempo fit
- FMiguelez
Re: Turning off the "auto" tempo fit
If I understand you correctly, you could turn that off somewhere in the Preferences. I'm not infront of DP now, so I don't remember where exactly (for the audio parts).
As for MIDI, if you already have a tempo map and you're moving things around and you want the music to play at the original tempo, you must use the Shift Command (with the Preserve Original Performance option checked), or move things around with Time Format settings that are anything except measures (e.g., real time). That is if you want to preserve the original performance tempo and nuance.
