Can someone tell me what these grey blocks are towards the bottom of the MIDI editor (just above the Mod wheel data) in the screenshot below:
http://imgur.com/eo2irn3
They appear randomly and if one does appear in a session, once I close the session I can't re-open it. I get the 'Unexpected end of file' error. I've also tried to load that chunk into a different session as well as importing the affected file as a MIDI file; neither of which work. If I spot them before I save and close, I can highlight and delete them just like any other CC and velocity data. Then everything will re-open as expected.
'Unexpected end of file' error and weirdness in MIDI Editor
8-core MacPro 4,1, 32 gb RAM, OS X 10.9.2, MOTU 8 Pre, DP 8.06, VePro 5
Re: 'Unexpected end of file' error and weirdness in MIDI Edi
Those blocks look like MIDI Controller events, bank change events, patch change events, etc. Hard to tell exactly what they are without selecting them and reading about them. That space is reserved for MIDI Control Change events which are formatted as switches. On/Off, that is. That's the default for Controller #64 on most piano patches.
I never liked controller events there. They overlap and are hard to reach. I use DP's pref function: "Switches are Continuous Data." Then they appear in the bottom panel with the other CC data. When using "Bar Mode," switches then show as swaths of color (on) or blank (off).
