Happening here with a quad satellite....jlaudon wrote:I think it's only Apollo users.
Cheers, AB
James Steele wrote:Thanks. Sorry if I was too lazy to go back and read it. I *wish* perhaps I was an Apollo user. That's a great interface consider how "future proof" it is with TB connectivity.jlaudon wrote:I think it's only Apollo users.
At the UA website, try downloading 7.30b. It's not listed as such, but when you download the latest OS this is what you'll get. I've worked around three hours now and have had only 1 Error -38. This is much better than things were a few days ago.bolla wrote:I tried going back to using UA version 7.01 but still the same issues.
-38 or just for a bit of variety -98.
Cheers, AB
It's work fine under Snow Leopard with D.P.8 in 7.3.0. version Universal Audio system: I think that's for the other systems used (Lion, Mountain LION & perhaps Mavericks) _James Steele wrote:Does this affect Snow Leopard users? I haven't tested it extensively, but I'm using 7.3.0 version and not having any problems.
Again, it appears that the error messages are affecting UAD Firewire devices only. BTW, I don't think that Thunderbolt users are affected either, but I'm not completely certain.corbo-billy wrote:It's work fine under Snow Leopard with D.P.8 in 7.3.0. version Universal Audio system: I think that's for the other systems used (Lion, Mountain LION & perhaps Mavericks) _James Steele wrote:Does this affect Snow Leopard users? I haven't tested it extensively, but I'm using 7.3.0 version and not having any problems.
Yes seemingly..............muscletn wrote:At the UA website, try downloading 7.30b. It's not listed as such, but when you download the latest OS this is what you'll get. I've worked around three hours now and have had only 1 Error -38. This is much better than things were a few days ago.bolla wrote:I tried going back to using UA version 7.01 but still the same issues.
Cheers, AB
Are your error messages also stemming from completely random DP actions?
Update from the trenches: I just finished a vocal session. Five tracks, many punch ins and edits on the spot. I was in Multi-Record mode in DP, so that I was able to use MIDI-triggered tones from Polysynth to help the singer with notes.muscletn wrote:At the UA website, try downloading 7.30b. It's not listed as such, but when you download the latest OS this is what you'll get. I've worked around three hours now and have had only 1 Error -38. This is much better than things were a few days ago.bolla wrote:I tried going back to using UA version 7.01 but still the same issues.
Cheers, AB
Yes, of course, Bolla. The specs were at the very beginning of my posting. Here goes:bolla wrote:Hey Muscletn,
Could you add some system specs to your signature?
I'm on an older 3,1 2008 2 X 2.8 quad.
Apparently, according to UA, users with older macs like mine have solved this by using one of their qualified FW800 cards. Sonnet and SIIG.
Before I go down that route I'm going to try a few other options.
Cheers, AB
Well according to my tech response from UA these errors are apparently fixed for users with a 3,1 or a 4,1 by using a qualified FW800 card and not using the FW800 ports of the Macpro.muscletn wrote:
2010 MacPro 8-core 2.26 (4,1) I'm running Mountain Lion 10.8.5, DP 8.05, the Apollo Quad, Black Lion Micro Clock II, a UAD-2 Duo PCIe, and a UAD-2 Solo PCIe. 16 gigs ram. WAVES, Sound Toys, Kontakt 5, Mach Five 3, Spectrasonics, Ivory, drum VI's.
Yes, I'm sure there are other forces at work!bolla wrote:Well according to my tech response from UA these errors are apparently fixed for users with a 3,1 or a 4,1 by using a qualified FW800 card and not using the FW800 ports of the Macpro.muscletn wrote:
However....
I'm having some success (so far) using the front panel FW800 port.
This is against tech support advice.
It's also Halloween so there may be other forces at work....
Cheers, Adrian
