8.05 bug report #1 Revert from full screen
Says it all. If I am in full screen mode and Revert to Saved, the resulting window looks like this:
A tiny little screen in the upper left corner. Ex-panding the screen then looks like this:
Window sets work to fix it, but any subsequently opened project opens to the tiny screen.
Relaunching DP seems to fix it. Expect an 8.06 soon... no?
Reported to MOTU techlinks.
rokko101
Re: 8.05 bug report #1 Revert from full screen
Post by rokko101 »
Same problem here. Please fix it Motu.
Send a tech link. You can reference this thread. They'll get to it.
Confirmed by MOTU. DP 8.05 can't be far off. This is a pretty big one IMO.
rokko101
Post by rokko101 »
Good to know.
Basically the problem arises when you CLOSE a Project in full Screen Mode. The only way out is to exit full screen out before closing the project. If not, you're forced to quit DP in order to work correctly again. Pretty annoying. Please MOTU take care of it. We love DP.
I don't use full screen mode, but I'm glad you found it. Full screen mode doesn't work well with Spaces (Control Panel won't float), but I'm guessing that a lot of people who don't use Spaces are using full-screen mode. It maximizes your spatial efficiency on the one screen. Can't have that being flaky.
I hope they'll fix it fast.
dado
Post by dado »
Uhm...I wait to upgrade, 8.0.4 rocks!
iMac 27" 3 ghz 32 Giga ram / DP 11 / Motu UltraLite mK4/ TLAudio Ivory 5051 / Addictive Drum2 / PRS Custom22 Guitar / Boss Katana100 / Line 6 Variax700 / Strat by Tino Tedesco
Julia123
Post by Julia123 »
Is full screen mode when you hit the green button in the upper left corner or some other function? I do this with the consolidated window and a separate Mixer window. Thanks.
iMac 27" 4.2 GHz i7 1TB SSD. 40 GB RAM. Apogee One.
It's the arrows in the upper right corner and i think you can only get there using the consolidated window.
davidthriller
Post by davidthriller »
I don't really use full screen mode, good thing you found it, though. The full screen mode increases efficiency of your local. I guess a lot of people who use the space, but when I'm using. The space doesn't work well in full screen mode
DP was forced to leave in order for it to work correctly, it's annoying, I know, but it's not enough either. Quite annoying. From now on, just before the close of the project it's derived from full screen. If you have a project close full screen mode, this is exactly why it's a problem which often occurs.
