It is currently Wed May 24, 2017 2:53 am
Text Size
Freezing Audio tracks seems a very slow process...
Postby zandurian » Sat Mar 02, 2013 9:49 pm
... in fact I found that freezing single audio tracks with a Melodyne plug inserted is pretty much a real time affair as a 5 minute song takes about 5 minutes to freeze. To test whether Melodyne was involved I opened a small (30 audio tracks - no VIs) project just to test the freeze speed and freezing a mono track with NO EFFECTS at all took just as long! I really would expect a faster freeze with a 2009 eight core computer with 12 gigs of RAM running 64bit with an SSD bootup drive and 7200 RPM project hard drive. The CPU and playback seem to be idling along under no duress whatsoever. I even disabled all tracks except for the one I was freezing and still pretty much the same result.
Thoughts?
Mac Pro 4,1 (early 2009) 2 x 2.26 GHz Quad-Core Intel Xeon 12 gigs RAM, OS 10.8.3, DP8.04, UAD2e, Superior drummer 2, Mach 5-2,Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2.1.0, Izotope RX2
zandurian
Re: Freezing Audio tracks seems a very slow process...
Postby MIDI Life Crisis » Sat Mar 02, 2013 9:57 pm
Freezing is essentially realtime bouncing. Bouncing takes less time. Freezing always processed realtime.
2013 Mac Pro 32GB RAM
OSX 10.12.3; DP 9.02; Track 16 Finale 2014.5
http://www.MIDI-Life-Crisis.com
Postby buzzsmith » Sun Mar 03, 2013 7:51 am
MIDI Life Crisis wrote:Freezing is essentially realtime bouncing. Bouncing takes less time. Freezing always processed realtime.
Yep.
DP 9.01 PCI-424e / original 2408, 2408mkII, 24I/O, MTP-AV
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
buzzsmith
Postby doodles » Sun Mar 03, 2013 5:21 pm
yep. read manual if you want full explanation, but freezing IS realtime - you can't make it go faster.
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
doodles
Postby MIDI Life Crisis » Sun Mar 03, 2013 5:27 pm
There's a manual? :shock:
Postby zandurian » Sun Mar 03, 2013 7:27 pm
doodles wrote:yep. read manual if you want full explanation, but freezing IS realtime - you can't make it go faster.
Wow - I had no idea and still have no idea why that would be. I guess the manual will explain that too. Except I probably won't take the time since I have to read it in real time. :oops:
zandurian
Postby zandurian » Sun Mar 03, 2013 7:32 pm
Then why would anyone ever freeze instead of bounce? Is these an old feature from when early VIs could not be bounced in anyway except in real time? I think I first started using freeze when a bounced superior drummer2 bounced track was off but the freeze was tight. Yet the manual claims bouncing will work with VIs and it mostly does but the superior drummer thing proved not always.
Okay - I'm going to read the manual now (something I do everyday now)
zandurian
Postby MIDI Life Crisis » Sun Mar 03, 2013 7:35 pm
zandurian wrote:Then why would anyone ever freeze instead of bounce?
It used to be that you couldn't bounce a VI but you could freeze it. Some people think bouncing not as reliable as realtime, so you have an option. I bounce. Or is that iBounce? iDon'tKnow.
Postby zandurian » Mon Mar 04, 2013 5:14 am
It is more reliable with certain VIs which I guess makes it the VIs fault? But freeze or bounce should (ideally - apparently not in DP) happen as fast as the drives and processor are capable of freezing or bouncing without introducing problems, right?
So my guess is that Freeze exists as a slow, plodding way to get plugs with sucky bounce behavior to be bounce to audio. Make sense?
I used to just arm tracks and record them real time as the song played. At least that way if it screwed up I wouldn't have to listen to the whole song again to find out the bad news.
zandurian
Postby mikehalloran » Mon Mar 04, 2013 6:05 am
Or is that iBounce?
I think iBounce is $1.99 in the App Store.
July 2010 iMac 2.93G i7 Quad, OWC eSATA mod, 32G RAM, OS 10.12.4
828mkII FW; MOTU MTP/AV USB with Firmware 2.0.1; DP 9.13, 9.02, 8.07 64bit, DP 7.24; IK-NI-Izotope-PSP-Garritan Antares, 32Lives, JBridge, MachFive 3.2.1
LogicPro X 10.3, Finale 25.3, 2014.5, Encore 5.0.7, Notion 6, Overture 5, TwistedWave, DSP-Q 4.4, QuickTime Pro 7.6.6, SmartScore Pro X2 10.5.5, Toast 15
Test machine: G4-1K Dual Processor: OS 10.4.11 / OS 9.2.2; DP 5.13; Encore 5.05 & 4.5.5; Toast 9.07b, legacy apps
Postby doodles » Mon Mar 04, 2013 4:54 pm
here's an example of when you would freeze:
Take a finished sequence containing 25 or 30 instances of VI's. (eg. VE Pro, Omnisphere, etc). Each has 16 mini channels. You want to print all the MIDI into individual audio channels to take to an external studio to mix. If you bounce, unless you've got some MAJOR routing going on, you would have to bounce 1 track at a time. With freeze, you can select 1 MIDI channel from EACH VI (25 or 30) and freeze all at once. Saves a •••• load of time. Crashes DP half the time though when you do too many at once. :lol:
doodles
Postby MIDI Life Crisis » Mon Mar 04, 2013 5:37 pm
Too bad that we can't freeze/bounce multi channels of all VIs to their respective tracks. UNless I'm missing something, unless you have that elaborate routing system in place, BTD on VI mixes the MIDI channels for that instantiation of the VI.
Postby doodles » Mon Mar 04, 2013 5:45 pm
by MIDI Life Crisis » 05 Mar 2013 12:37 am
i know. I keep meaning to start a thread to get people's input on best way to do it, as tracklaying for soundtracks takes forever. I WISH there was a way just to freeze all tracks selected at once, no matter how many MIDI channels going to each VI. There's obviously a reason why not, I just can't think. It would save literally days.
doodles
Postby zandurian » Mon Mar 04, 2013 8:23 pm
In the past I've taken all the vi tracks, multitrack drum VIs etc and and bussed them to real audio tracks, arm and hit record. Of course the problem comes in when you have one multi-timbral VI doing a bunch of stuff to stereo outs. With Mach 5 2 I just open multiple instances and keep it one instrument per instance but that's a bit nuts.
I don't know what the freeze/bounce capabilities of Mach 5 v3 are because I haven't even installed it yet.
zandurian
Postby MIDI Life Crisis » Mon Mar 04, 2013 8:50 pm
On a multi-core machine each instance of a VI gets a difference core so as MagicD says: spread the wealth! One instrument per instance is good!
Next
Return to Digital Performer [MacOS]: Troubleshooting/Criticism
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
Who is online
In total there are 4 users online :: 2 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
Login Form
