I used to merge soundbites all the time so that when sending to someone else, it made importing files easy.
For some reason, I can't get this to work.
I've tried dragging over the entire length of the track, using the region selection tool, etc.. but the merge command is still greyed out.
I've looked in the manual but it doesn't elaborate much on merging.
Can someone please help?
Cheers,
Sam
Merging soundbites in tracks window
- Radiogal
Re: Merging soundbites in tracks window
I always merge in the SE window.
MAC PRO 6 Core 3.33 GHz, 16 GB RAM, OSX 10.8.5, DP 9 MAC and WIN (64bit/Jbridge) AMPGUI Mellow, Logic 10, Wavelab 8 MOTU 24I/O (x2), MOTU 2408 MK3 (2x), WAVES Mercury 9, SSL, UAD2Quad, McDSP, Sound Toys, Sonnox, Sonalksis, NomadFactory, T-Racks, P&M, LexPCM, AbbeyRoad, DSM, VCC, VTM, FGX, Melda, EWQL SymphOrch/Piano Gold. Mixingdesk: AMEK Big 44, TK BC-1MK2, SSLcomp clones, GAPPre73, PCM91, TC, FMR. Monitors: Genelec 1031, ADAM A7, >40 mics http://www.ragdollproduction.com
Just got this problem! Can't merge soundbites what so ever.
DP 806 on Macbook OS 10.8.2
Mac Pro 2X quad core 2.26 Ghz, 22 GB RAM, OS 10.8.4 | DP 8.05 | 2408MKII
Beta Tester for Toontrack
- Dan Worley
Merge Soundbites works here. I'm glad you brought it up though, because I usually test it after each release to make sure it's working properly and sample accurate and there are no glitches around the edits. I forgot to do that with 8.06. I just tested it right now and it is working as expected.
I can't think of a reason why it wouldn't be working.
Maybe trash the preferences.
DP10.13
Working now. I mixed up the merge in the edit menu with merge soundbites in the audio menu. But from what i remember, both didn't work, but all is good now.
- Dan Worley
Ah, yes, I've done that too. That could also be the OP's mistake.
DP10.13
