It is currently Fri May 24, 2013 1:50 pm
Text Size
No MIDI notes when saving a MIDI file in DP
Postby XXF » Fri Jul 13, 2012 2:13 pm
Hello. I am having trouble getting MIDI notes to appear when saving my DP sequence as a MIDI file. I hit Save As, chose Standard MIDI file, clicked Format 1. The MIDI file is saved, but when I open it, everything is there including track names but no MIDI notes. I trashed preferences and that didn't work. I am on DP 4.6. OS 10.4.11. MOTU tech support didn't have much to offer Any help? Thank you.
XXF
Re: No MIDI notes when saving a MIDI file in DP
Postby FMiguelez » Fri Jul 13, 2012 11:23 pm
I think I recall something about this happening when the tracks are muted in the source (the sequence you use to create the .mid file).
Give it a try.
Mac G5 dual 2GHz/4 GB RAM / OSX 10.5.8 / DP 7.24
Tascam DM-24, Yamaha 01v, MOTU 2408 MK3, MOTU MTP AV USB, all Spectrasonics' stuff,
Vienna Instruments SUPER PACKAGE, Waves Platinum, slaved Macs running VI Pro and VE Pro
“In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth.” ― Richard Feynman
FMiguelez
Postby XXF » Sat Jul 14, 2012 12:02 am
Interesting. That's a great suggestion. Now that I think of it, I mute MIDI tracks after outputting them to audio all the time. Definitely gonna check that first thing tomorrow. Thanks.
XXF
Postby doodles » Sun Jul 15, 2012 12:08 pm
don't you also need to select the tracks and area you want to export/save as MIDI?
2*8-core 3.0 (16 gigs RAM),dual 2.5 (8 gigs RAM), DP 7.2, WAVES 5, all Spectrasonics, Mach 5 v2.0.2, all Vienna Ensemble (extended), LASS, Ethnoinstrument, all NI (version 5), Evolve, Symphobia, TrueStrike 1 and 2, Cinetoms, Drums of War
doodles
Postby XXF » Mon Jul 16, 2012 6:04 pm
Hey FMiguelez. You were absolutely correct. Thank you. Good thinking. You don't need to highlight anything. Just make sure the MIDI channel faders are up, and the MIDI notes will appear.
XXF
Return to Digital Performer [MacOS]: Troubleshooting/Criticism
Who is online
Users browsing this forum: Google [Bot], Ksmccarthy and 5 guests
Who is online
In total there are 7 users online :: 2 registered, 0 hidden and 5 guests (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
