Any way to reset delay compensation or fix sync problem?
Posted: Sat Jul 07, 2012 9:12 pm
A couple times now I've gotten myself into trouble by recording audio tracks AFTER I've added Ozone to the Master Bus, and wound up with tracks that sound correct when recording, but late on playback (about 70 ticks). I can slide the tracks earlier so they sound correct on playback, but it's irritating, and a little nerve-racking with clients around, to have to do something like that.
Does anyone know a way to reset whatever breaks when recording with certain plugins on the Master Bus? I've trashed DP prefs, Ozone prefs, MAS prefs, checked CueMix FX to see if the monitoring delay might be there (although I didn't trash CueMix prefs), repaired permissions, re-started, removed Ozone from the Master Bus, set unused Inputs to "None", toggled Delay Compensation, tried all the Monitoring options.... nothing's worked so far.
I think I can work around the tracking issue by using a 2nd Mix with no plugins, but I just would like to know if the sync problem in the original Mix can somehow be fixed?
BTW, I'm using Direct Monitoring through CueMix FX when recording, so this isn't a latency issue. I'm also bussing all instruments to Subgroup Auxes, which then go to a Master Fader Aux, which in turn goes to a MIX bus (where Ozone and other plugins reside), which then outputs to the 828mk3 Toslink Out for monitoring through a Central Station.
Any help would be greatly appreciated!
