It is currently Thu May 23, 2013 2:32 pm
Text Size
Track lock not working?
Postby Anders Peev » Thu Jun 28, 2012 7:51 am
I'm working on a film trailer and playing around with the find tempo feature. Every time I try a new tempo the soundbites in the voice over track moves along. I've checked that the track is locked.
What obvious thing am I missing here? I'm not suppose to have to select every soundbite and do move to original time stamp every single time I use find tempo??
Anders
Digital Performer 7.22/ MacPro 2x2.66 Dual-Core Intel-Xeon/ 8GB RAM, Mac OS 10.5.8, RME Fireface 400/ Golden Age Pre-73 / ADK TC12 / ADK S7/ ADK SB / LIne CM3 x 2, Golden Age R1 / Adam A7 x 2 / Quick Time Pro 7.4 / and lots of acoustic instruments.
http://www.nanoqrecordings.com
Anders Peev
Re: Track lock not working?
Postby magicd » Thu Jun 28, 2012 11:27 am
Anders Peev wrote:I'm working on a film trailer and playing around with the find tempo feature. Every time I try a new tempo the soundbites in the voice over track moves along. I've checked that the track is locked.
Anders
When you change the sequence tempo, events in locked tracks will appear to have moved in relation to bars and beats. However, the SMPTE time of these events will not change. You may want to set the time displays to show SMPTE as well as bars and beats (Setup menu>Time formats).
Dave
magicd
Postby Anders Peev » Sat Jun 30, 2012 9:13 am
Thanks Dave!
I think I found out what my real problem was:
As soon as I change the meter for one or two bars before my Q starts the sequence starting point changes to a point before the film. I do this in order to line up the q-start with a first-beat in a bar after I've found a new tempo.
I am sure this is all normal but I don't know how to deal with it. Should I do something special in the "change meter" dialog box in order to prevent the film getting out of sync with the sequence?
Anders
Anders Peev
Postby frankf » Sat Jun 30, 2012 8:47 pm
Anders Peev wrote:Thanks Dave!
Anders
It perfectly normal. You are snipping or inserting time in the time line when you change meter or tempo after setting the sequence start time. Try separating each cue into it's own sequence. You won't have the problem you describe. This issue can also come up inside a cue as well, for example when the editor makes changes to a scene and you have to adjust the music.
Frank
Frank Ferrucci
http://www.ferruccimusic.com
Mac Pro 3,1 24gb RAM DP8.03 OSX 10.8.3 MIO 2882d &ULN2d Firewire Audio Interfaces
frankf
Return to Digital Performer [MacOS]: Troubleshooting/Criticism
Who is online
Users browsing this forum: Brancat, Gravity Jim, stephentayler and 1 guest
Who is online
In total there are 4 users online :: 3 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
